Version of Cinema 4D | Supported Operating System |
R20 | Windows ® 8.1 and Windows ® 10 Professional |
R21 | Windows ® 8.1 and Windows ® 10 Professional |
S22 | Windows ® 8.1 and Windows ® 10 Professional |
R23 | Windows ® 8.1 and Windows ® 10 Professional |
R24S24 | Windows ® 8.1 and Windows ® 10 Professional |
R25 | Windows ® 10 Professional |
macOS
Processor | Intel 64, AMD64, ARM 2 or compatible processor with SSE4.2 support |
RAM | 8 GB RAM or 8 GB swap minimum – recommended 64 GB RAM or more; (Actual amount required will vary with scene requirements.) |
Operating system | Apple ® macOS ® X 10.14 or later |
TCP/IP | Only IPv4 required for distributed rendering is supported. IPv6 is currently not supported |
License Server | 5.5.0 or later |
UI Text Box | ||
OpenCL with both AMD and Nvidia cards is not supported with V-Ray for Cinema 4D on macOS. |
The following table shows the versions of Cinema 4D and operating systems on which V-Ray is supported. Note that V-Ray is only supported for 64 bit operating systems.
Version of Cinema 4D | Supported Operating Systems |
R20 | Apple ® macOS ® X 10.14 or later |
R21 | Apple ® macOS ® X 10.14 or later |
S22 | Apple ® macOS ® X 10.14 or later |
R23 | Apple ® macOS ® X 10.14 or later |
S24 | Apple ® macOS ® X 10.14 or later |
R25 | Apple ® macOS ® X 10.14 or later |
1 1
Anchor | ||||
UI Text Box | ||||
V-Ray Node space is available in Cinema 4D versions 21.1 and later! |
2
Anchor | ||||
