Exporting V-Ray Scene Files
- If you do not want to render your scene when exporting the .vrscene, disable the Render option option.
- Enable and expand the Export to a. vrscene file rollout.
Set the directory and the name of the file in the File name field below.
Section Column width 25% Column width 50% Column width 25% - Click on the Start Production Render button ()Go to the V-Ray menu and click on Start Production Render to save the .vrscene.
