This page provides information about submitting render and bake jobs to Chaos Cloud from V-Ray for Unreal. HideElements cssselector #tocVertical, #tocHorizontal
Section | |||||||||||||||
UI Text Box | ||
Light baking is inherently computationally intensive process and will consume more resources than a traditional rendering. The total amount of consumed cloud credits depends on the number of objects in the level, their light map resolution, the quality settings and the lighting complexity in the level. Please make sure your scene has the desired settings prior submitting. Please make sure you test and estimate prior submitting. |
UI Text Box | ||
Smaller atlas size means more computers will process the baking, which speeds up the rendering at the expense of credit cost. |
Tabs Container | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
