Windows
Please make sure that your system fulfills these requirements before installing V-Ray. For additional information on hardware, see the Hardware Recommendations article.
Processor
Intel* 64, AMD64 or compatible processor with SSE4.2 support
RAM
Minimum 8 GB RAM, recommended 16 GB RAM
Hard Disk Spaceminimum 2GB, recommended 12GB (includes additional downloadable content)
TCP/IP
Only IPv4 is supported. IPv6 is currently not supported
Operating System
Windows 10, Windows 11
SketchUp
SketchUp 2019, 2020, 2021, 2022, 2023, 2024
GPU Support
NVIDIA GPUs of Maxwell generation or later with the latest recommended video driver (for both CUDA and RTX - enabled cards)
V-Ray Vision requires a Graphics card with DirectX 11 or DirectX 12 and Shader Model 5.0 capabilities
macOS
Processor
Intel 64, AMD64, ARM64 or compatible processor with SSE4.2 support
RAM
TCP/IP
Operating SystemApple® macOS 10.15 Catalina or higher
SketchUpSketchUp 2019, 2020, 2021, 2022, 2023, 2024
UI Text Box
sizemedium
typewarning
V-Ray GPU is not officially supported on macOS.
It works only with C++/CPU devices. V-Ray GPU can still be used in distributed rendering where a macOS machine runs the CUDA engine on a CPU device together with Windows/Linux machine(s) running CUDA engine on GPU device(s).
Anchor
note
note
UI Text Box
typenote
Customer support is available only for V-Ray 6 and V-Ray 5. Earlier versions are no longer supported.
