Please make sure that your system fulfills these requirements before installing V-Ray. For additional information on hardware, see the Hardware Recommendations article.
Processor | Intel* 64, AMD64 or compatible processor with AVX2 support |
RAM | Minimum 8 GB RAM, recommended 16 GB RAM |
Hard Disk Space | minimum 2GB, recommended 12GB (includes additional downloadable content) |
TCP/IP | Only IPv4 is supported. IPv6 is currently not supported |
Operating System | Windows 10, Windows 11 |
SketchUp | SketchUp 2019, 2020, 2021, 2022, 2023, 2024 |
GPU Support | NVIDIA GPUs of Maxwell generation or later with the latest recommended video driver (for both CUDA and RTX - enabled cards) V-Ray Vision requires a Graphics card with DirectX 11 or DirectX 12 and Shader Model 5.0 capabilities |
Processor | Intel 64, AMD64, ARM64 or compatible processor with AVX2 support |
Operating System | Apple® macOS 10.15 Catalina or higher |
UI Text Box | |||
In V-Ray GPU is not officially supported on macOS.It works only with C++/CPU devices. V-Ray GPU can still be used in distributed rendering where a macOS machine runs the CUDA engine on a CPU device together with Windows/Linux machine(s) running CUDA engine on GPU device(s)7, macOS Metal support has been added on Sonoma, Sequoia and newer OS. |
Anchor | ||||
UI Text Box | ||
Customer support is available only for V-Ray 6 and V-Ray 5later. Earlier versions are no longer supported. | ||
UI Text Box | ||
V-Ray 5 for SketchUp, update 2.2 is the last version that runs on macOS 10.10, 10.11, 10.12 and 10.13 . |
UI Text Box | ||
Windows 11 is required for running Intel Alder Lake processors. |
