changes.mady.by.user Kristin Ivanova
Saved on Jan 18, 2021
changes.mady.by.user Lyubomira Toshkova
Saved on Nov 09, 2021
GPU rendering allows V-Ray to perform raytracing calculations on the GPUs installed in the system.
V-Ray Interactive Rendering (IR) provides interactive rendering using the V-Ray and V-Ray GPU renderers.
Viewport Rendering (VPR) is a render output overlay on top of SketchUp's viewport. With Viewport Rendering, the scene is rendered interactively and if changes are made, the rendered result is updated.
V-Ray Vision is a real-time viewer introduced with the release of V-Ray 5 for SketchUp.
V-Ray Batch Rendering
allows for scenes to be set with tabs and rendered with one button.
This page provides tables of features supported in CPU and GPU rendering with V-Ray in SketchUp.
V-Ray for SketchUp provides in-built integration with Chaos Cloud, allowing you to submit render jobs to the cloud directly from SketchUp.
V-Ray Swarm controls V-Ray Distributed Rendering on each render node machine; the actual rendering is handled by V-Ray Standalone.
