Section | |||||||||||||||||||
Why V-Ray GPU?
V-Ray GPU has a number of advantages:
- Graphics cards often outperform CPU devices when it comes to processing parallel tasks, such as raytracing;
- A single machine can host multiple GPU devices but in most cases only a single CPU;
- Hybrid rendering (CUDA only) allows rendering allows maximum hardware utilization by harnessing the computing power of both GPU and CPU devices;
- V-Ray GPU has all the required features to be production ready;
V-Ray CPU advantages:
- Allows rendering complex scenes requiring a substantial amount of memory;
- Supports all V-Ray features;
- Does not pre-occupy single-GPU machines during rendering.
Supported Hardware and Drivers
Fancy Bullets | ||
UI Text Box | ||||
Тo use NVLINK on supported hardware, NVLINK devices must be set to TCC mode. This is recommended for Pascal, Volta and Turning-based Quadro models. For GeForce RTX cards, a SLI setup is sufficient. Also note that to prevent performance loss, not all data is shared between devices. For more information, see the OptiX and NVLink FAQ page. | ||||
UI Text Box | ||||
V-Ray GPU is not officially supported on macOS. It works only with C++/CPU devices. V-Ray GPU can still be used in distributed rendering where a macOS machine runs the CUDA engine on a CPU device together with Windows/Linux machine(s) running CUDA engine on GPU device(s). |
Choosing Which Devices to Use for Rendering
When selecting devices from the standalone tool, that will set the default setup for the work station. After changing this option, you need to restart SketchUp and/or any Standalone DR servers (if any are running) for the changes to take effect. If the Standalone DR server is running as a service, you may need to restart it.
When choosing the devices from the Asset Editor - it is done only for the current session in SketchUp.
UI Text Box | ||
If you see your CPU listed twice, choose the option with "C++/CPU " in the name. |
Hybrid Rendering with CPUs and the
GPU Engine Anchor #Hybrid #Hybrid
#Hybrid | |
#Hybrid |
Starting in 3.60, V-Ray GPU can perform hybrid rendering with the CUDA GPU engine utilizing both the CPU and NVIDIA GPUs. V-Ray can now execute the CUDA GPU source on the CPU, as though the CPU was another CUDA GPU device. To enable the hybrid rendering mode, simply enable the C++/CPU device from the list of CUDA devicesGPU devices. You can specify whether the GPU engine uses CUDA or RTX cards.
The hybrid rendering mode does not require any special drivers. Furthermore, you can use the CPU as a CUDA GPU device even if you don't have an NVIDIA GPU and/or NVIDIA drivers installed. Meaning, this mode can be used on computers that don't even have GPUs. The hybrid render engine running on a CPU supports the same features as features as the regular V-Ray GPU CUDA engine.
More info about the nature of Hybrid rendering is available at the blog post Understanding V-Ray Hybrid rendering.
Memory usage can be viewed from the Stats section of the new V-Ray Frame Buffer.
MacOS Metal support is added with V-Ray 7 on Sonoma, Sequoia and newer OS.
References
Fancy Bullets | ||
