Section | |||||||||||||||
UI Paths
VFB Menu
The V-Ray Frame Buffer menu holds the main frame buffer commands. Some of the options are also available in the VFB toolbar for quick access.
A search field where you can filter the images based on the scene's paths and notes. |
Section | |||||||||||||||||||||||||
Layers
The New V-Ray Frame Buffer includes a suite of color corrections and tools for adjusting the image. The tools are added as layers and displayed in a layer tree. You can enable or disable a particular tool using the visibility icon () to the left of its name.
Section | |||||||||||||||||||||||||||||
Stats AnchorStats Stats
Stats | |
Stats |
Log
VFB Shortcuts
These shortcuts navigate through the VFB image. Please note that the VFB window must have the current focus for the shortcuts to have effect:
