The V-Ray Asset Editor is the place where you can create, save , and open assets, and adjust their settings. These include materials, textures, geometry, and lights. You can also manage the Render Channels from the Asset Editor. From its Settings tab, you can choose the render engine, set up the camera, optimize the render process, or render with Swarm. You can also start the render or submit a scene to Chaos Cloud, as well as open the VFB.
UI Paths
Functionalities
Section | ||||||||||||||||||||||||||||||
Section | ||||||||||||||||||||||||||||||||||||||||||||
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Render Button
Render Button
V-Ray Frame Buffer Buttons
1 - Sliders are allowed to be focused and controlled by the keyboard. The visual indication that a slider is focused, is the same as if you have hovered over it. Anchor 1 1
