Section | |||||||||||||||
Anchor | ||||
Sky
Example: Customize the sky with procedural clouds
Align | ||
Example: Direction of the V-Ray Sun Light
Common settings in this example are Turbidity: 3.0, Intensity Multiplier: 0.01, Size Multiplier: 1.0. This example demonstrates the effect of the sun direction. Note how in addition to the scene brightness, the sun position also changes the appearance of the sky and the sun light color.
Section | ||||||||||||||||||||||||||||||||
Example: The Size Multiplier Parameter
Common settings in this example are Turbidity: 3.0, Intensity multiplier: 0.01. This example demonstrates the effect of the Size multiplier parameter. Notice how changes in this parameter affect both the visible sun size and the shadow softness (however overall illumination strength remains the same).
Example: The Turbidity Parameter
Common settings in this example are Intensity Multiplier: 0.01, Size Multiplier: 1.0. This example demonstrates the effect of the Turbidity parameter. Generally, this controls the amount of dust particles in the air. Notice how larger values cause the sun and the sky to become yellowish while smaller values make the sky clear.
Example: The Intensity Multiplier Parameter
Align | ||
Anchor | ||||
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Anchor | ||||
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Anchor | ||||
Anchor | ||||
Anchor | ||||
Anchor | ||||
Example: Ozone Value
Common settings in this example are Turbidity: 2.0, Intensity Multiplier: 0.01, Size Multiplier: 10.0. The Ozone parameter affects only the color of the light emitted by the sun.
Anchor | ||||
Options
Anchor | ||||
Fancy Bullets | ||
Anchor | ||||
