The Two Sided material is a utility material provided with the V-Ray renderer. The material allows seeing the light on the backside of the objects. Use this material to simulate thin translucent surfaces like paper, cloth curtains, tree leaves, etc.
UI Text Box
type
info
The Two Sided material settings are organized in Basic and Advanced modes. You can switch the mode from the toggle button () under the Preview Swatch or globally from the Configuration rollout of the Settings tab.
UI Text Box
type
tip
The context options of the Color Slot allow to Copy and Paste a color from one color slot to another, as well as to reset the color selection.
UI Text Box
type
tip
A Reset option is provided in the context menu of each Number Slider. You can reset the slider value to the default one.
width
5%
width
35%
Image RemovedImage Added
UI Path
||V-Ray Asset Editor|| > Materials (right-click) > Two Sided
