Section | |||||||||||||||
UI Path
||V-Ray Asset Editor|| > Materials (right-click) > Hair
||V-Ray Asset Editor|| > Materials (left-click) > Hair
UI Options
Diffuse
Primary Specular
Secondary Specular
Transmission
Section | |||||||||||||||||||||||||||||||||||||
Options
Multipliers
Override Control
Can be Overriden – When enabled, the material can be overridden when you enable the override color option in the Global Switches.
Attributes
The attributes from the following expandable menus are available for the Hair material.
Anchor | ||||
Expand | |||||||||||||||||
Raytrace Properties
Expand | ||||||||||||||||||||||
Material ID
