Section | |||||||||||||||
UI Path
||V-Ray Asset Editor|| > Materials (right-click) > Subsurface Scattering
||V-Ray Asset Editor|| > Materials (left-click) > Subsurface Scattering
UI Options
Section | |||||||||||||||||||||||||||||||||||
Diffuse Layer
Sub-Surface Layer
Specular Layer
Scattering Options
Section | |||||||||||||||||||||||||||||||||||||||||||||||
Multipliers
Binding
Override Control
Can be Overridden – When enabled, the material can be overridden by the Material Override option in the Settings.
Expand | ||||||||||||||||||||||
Material ID
Fancy Bullets | ||
References and Links
Here is a list of links and references used when building the BRDFSSS2Complex material.
