This page provides information about the Stochastic Flakes material in V-Ray for SketchUp.
Section | |||||||||||||||
UI Options
Base Parameters
Anchor | ||||
Example: Enable Flakes
Section | |||||||||||||||||||||||||||||||
When this option is disabled, the continuous GGX distribution is rendered.
Anchor | ||||
Example: Number of Flakes
Section | |||||||||||||||||||||||||||||||||
Anchor | ||||
Example: Highlight Glossiness
Anchor | ||||
Example: Blur Angle
Colored Flakes
Anchor | ||||
Example: Random Color Map
The Random Color Map parameter allows the user to provide a texture map for randomizing the stochastic flake colors. It is only accessible when Colored Flakes is set to Random from Map. Random colors are generated by sampling the horizontal row of pixels at the very bottom of the map along the U-axis. The sample area is only 1 pixel tall; the rest of the map is ignored.
Advanced Options
Multipliers
All other material settings are part of the Generic material and can be found on the Generic material page.
Anchor | ||||
