This page provides information on how the latest version of V-Ray handles scenes saved with previous versions of V-Ray.
V-Ray 7 adds a number of rendering optimization features. However, for compatibility reasons, some features and workflows have been adjusted and are discussed in detail below.
V-Ray for SketchUp is not forward-compatible, meaning projects done with V-Ray 6 are not guaranteed to work with V-Ray Next or older previous versions. If a project is opened using an older V-Ray version than the one it was created with, a prompt message will offer offers wiping all V-Ray data to ensure file stability.
GPU
Starting with V-Ray 7 the CUDA and RTX are replaced with a GPU tab for render engine. V-Ray GPU uses NVidia CUDA or RTX device(s) to perform the raytracing calculations. The GPU engine can be specified from the V-Ray GPU rollout.
Lights
The Portal Light option in V-Ray Rectangle light is now a legacy option and is no longer exposed in the UI. This is done because with the introduction of the adaptive sampling for dome lights and environments, the Skylight portals are not needed anymore.
The VRayMtl now has built-in Bump parameters. This allows users to set up linear shaders that are more optimal for rendering. It also keeps the workflow up to date with other host apps, such as 3ds Max and Maya.  Materials Materials previously using the Bump attribute now use the built-in Bump.
Starting with V-Ray 6, the V-Ray Preset Material Library is part of the Chaos Cosmos Browser. Materials that have already been downloaded with any earlier V-Ray version remain unchanged and can still be loaded as a custom folder.
Starting with V-Ray 7, the Binding section in the materials is now renamed to Viewport Display. The Texture helper has been removed and can now be replaced with a custom texture.
Enscape Compatibility
 Scenes set up using Enscape will now render in V-Ray. Materials and even the Enscape assets will be automatically handled by V-Ray providing a great starting point when transitioning from the Enscape design stage to the high-end visualization in V-Ray. For more information, go to Enscape Compatibility
Special Objects
Starting with V-Ray 7 there is a new Remove from Selection function. It removes the Special object applied on another object.
A new Contours rollout is added to the Settings. The rollout exposes a toggle that enables or disables global Contours.
Migration from Previous Versions
V-Ray 6 for for SketchUp licenses also work with V-Ray 5, allowing anyone who purchases an upgrade, to complete unfinished projects using V-Ray 5 if needed.
UI Text Box
typenote
Please note that customer support is available only for V-Ray 6 7 and V-Ray 56. Earlier versions are no longer supported.
If you need to migrate an outdated scene, you will need to perform a 2-step migration - the first one to V-Ray 3.6 and the second one to V-Ray 5.
To do so, first, visit download.chaosgroupchaos.com, enable the Show older versions checkbox, and download V-Ray 3.6.
