The settings in some of the rollouts are organized in Basic and Advanced mode. You can switch the mode from the toggle button () located next to the rollout title or globally from the Configuration rollout.
UI Text Box
type
info
You can restore, save and load V-Ray settings (in a .vropt file format) from the bottom three buttons in the Settings panel area. The three options are Load Render Settings from File..., Save Render Settings to File... and Revert to Default Render Settings. These options are inactive during rendering.
The Advanced Camera Parameters rollout can be found on the Camera settings page. The Denoiser rollout can be found under the Render Elements page. The Animation rollout toggle remains grayed out unless an animation is set up in SketchUp. For more information, see the Animation rollout page.
Provides convenient access to common Rendering functions such as choosing the render devices or turning on and off V-Ray Interactive and Progressive mode.
Textboxcard
PageToInclude
System Requirements
CardPageLink
Camera
Camera
The Camera rollout controls the way the scene geometry is projected onto the image.
Textboxcard
PageToInclude
Installation
CardPageLink
Render Output
Render Output
A number of output settings can be accessed through the Settings tab of the V-Ray Asset Editor.
Textboxcard
PageToInclude
Installation
CardPageLink
Animation
Animation
From the Animation rollout you can set a frame range for animated scenes.
Textboxcard
PageToInclude
Getting Started
CardPageLink
Environment
Environment
You can specify a color or a texture map to be used during GI and reflection/refraction calculations.
Textboxcard
PageToInclude
Getting Started
CardPageLink
Material Override
Material Override
You can specify a color or a material to be used to override all other materials in the scene.
Textboxcard
PageToInclude
Getting Started
CardPageLink
Swarm Settings
Swarm Settings
You can specify the Swarm settings.
Textboxcard
PageToInclude
Getting Started
CardPageLink
Render Parameters
Render Parameters
You can control the Progressive and the Bucket image samplers, select an Antialiasing Filter, specify a number of Optimization settings.
Textboxcard
PageToInclude
Getting Started
CardPageLink
Global Illumination
Global Illumination
You can specify the options of the lighting in a scene/environment.
Textboxcard
PageToInclude
Getting Started
CardPageLink
Volumetric Environment
You can see and adjust the settings of the volumetric effects Aerial Perspective and Environment Fog.
Textboxcard
PageToInclude
Getting Started
CardPageLink
ContoursOutlines
Contours
Outlines
The global Contours Outlines rollout gives you more control over linework, making it easier than ever to give your renders an illustrative look.
Textboxcard
PageToInclude
Getting Started
CardPageLink
Denoiser
Denoiser
The denoisers in V-Ray take an existing render and apply a denoising operation to it after the image is completely rendered out via normal means.
Textboxcard
PageToInclude
Getting Started
CardPageLink
Configuration
Configuration
You can globally configure the Properties display of newly created assets, as well as of already existing ones.
