width5%
width45%
 ||V-Ray Asset Editor|| > Settings
Image RemovedImage Added
width5%
width40%
UI Text Box
typenote
The settings in some of the rollouts are organized in Basic and Advanced mode. You can switch the mode from the toggle button () located next to the rollout title or globally from the Configuration rollout.
UI Text Box
typeinfo
  • You can restore, save and load V-Ray settings (in a .vropt file format) from the bottom three buttons in the Settings panel area. The three options are Load Render Settings from File...Save Render Settings to File... and Revert to Default Render Settings. These options are inactive during rendering.
  • The Advanced Camera Parameters rollout can be found on the Camera settings page. The Denoiser rollout can be found under the Render Elements page. The Animation rollout toggle remains grayed out unless an animation is set up in SketchUp. For more information, see the Animation rollout page.
width5%
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
alignleft
classdashboard
Textboxcard
PageToIncludeSystem Requirements
CardPageLinkRender
Render
Provides convenient access to common Rendering functions such as choosing the render devices or turning on and off V-Ray Interactive and Progressive mode.
Textboxcard
CardPageLinkCamera
Camera
The Camera rollout controls the way the scene geometry is projected onto the image.
Textboxcard
PageToIncludeInstallation
CardPageLinkRender Output
Render Output
A number of output settings can be accessed through the Settings tab of the V-Ray Asset Editor.
Textboxcard
CardPageLinkAnimation
Animation
From the Animation rollout you can set a frame range for animated scenes.
Textboxcard
PageToIncludeGetting Started
CardPageLinkEnvironment
Environment
You can specify a color or a texture map to be used during GI and reflection/refraction calculations.
Textboxcard
CardPageLinkMaterial Override
Material Override
You can specify a color or a material to be used to override all other materials in the scene.
Textboxcard
CardPageLinkSwarm SettingsDistributed Rendering
Swarm Settings
You can specify the Swarm settings.
Textboxcard
CardPageLinkRender Parameters
Render Parameters
You can control the Progressive and the Bucket image samplers, select an Antialiasing Filter, specify a number of Optimization settings.
Textboxcard
CardPageLinkGlobal Illumination
Global Illumination
You can specify the options of the lighting in a scene/environment.
Textboxcard
CardPageLinkVolumetric Environment
You can see and adjust the settings of the volumetric effects Aerial Perspective and Environment Fog.
Textboxcard
CardPageLinkOutlines
Outlines
The global Outlines rollout gives you more control over linework, making it easier than ever to give your renders an illustrative look.
Textboxcard
CardPageLinkDenoiser
Denoiser
The denoisers in V-Ray take an existing render and apply a denoising operation to it after the image is completely rendered out via normal means.
Textboxcard
CardPageLinkConfiguration
Configuration
You can globally configure the Properties display of newly created assets, as well as of already existing ones.
