Background – Specifies a color/texture map to be visible in the background and used during GI and reflection/refraction calculations. Press the checkerboard button to select a texture. If a texture is selected, it overrides the color as long as the texture checkbox is enabled.
GI (skylight) – Specifies a color/texture map to override the Environment GI rays. The effect of changing the GI environment is similar to a dome light. Note that Global Illumination (GI) must be enabled.
Reflection – Specifies a color/texture map to override the Environment reflection rays. Note that you can also override the reflection environment on a per material basis (see Generic) or a per map basis. If you do not enable the Refraction override, this group of controls affects both reflections and refractions. If you enable the Refraction override, then this group affects only reflections.
Refraction – Specifies a color/texture map to override the Environment refraction rays. This color is ignored if there is an environment texture specified.
Secondary Matte – Specifies a color/texture map to override the Environment rays affecting Matte objects.
The above GI environment overrides have the following common controls:
On – Enables or disables the specified GI environment override. Not available for the Background only.
Texture – Specifies a color or texture for the specified override. Note that Texture Enable must be enabled to have an effect on the scene.
Texture Enable – Enables or disables the specified GI texture.
UI Text Box
type
note
The textures used in Environment are always loaded in full size, regardless of the GPU Texture Mode setting.
The Environment map slot automatically sets its slotted texture as a global texture in the Textures List. All subsequent textures created in that slot have a prefix "Environment" in their name and are automatically set as global textures as well.
A bitmap image (HDRI) set set in any Environment map slot automatically uses a UVWGenEnvironment Spherical Mapping Type placement. The rotation of the image can be adjusted from the Bitmap UVW options using the Vertical and Horizontal rotation parameters. For more information, see the Bitmap page.
