Enabled – Turns Swarm, V-Ray's web-based distributed rendering system, on or off.
Goal Slider – Sets the desired percentage of utilization of available resources. Computers added or removed to V-Ray Swarm are taken into account automatically.
V-Ray Swarm ( ) – Opens up the V-Ray Swarm web interface of the current Coordinator machine. Alternatively, it can be accessed by typing in the IP address of the current Coordinator machine on the default port 24267. This allows you to see the swarm render node machines available for rendering jobs in your network. You can see which of the render node machines are connecting to the particular machine that is casting out the render to the Swarm by the IP address next to its status. This interface allows you also to configure the render node machines, tag them, or monitor their resource utilization while rendering.
