This page provides information about the Irradiance Map GI engine.
UI Text Box | ||
This is a legacy option that will be removed in the future. Use the other Global Illumination options instead. |
The Irradiance Map engine can be used to calculate global illumination. It works by creating a map with a collection of points in 3d space along with the computed indirect illumination at those points. This rollout allows the user to control and fine-tune various aspects of the irradiance map.
V-Ray includes an Irradiance Map Viewer for viewing and editing irradiance map files.
UI Path
||V-Ray Asset Editor|| > Settings > Global Illumination > Irradiance Map
(When Irradiance Map is set as the Primary Rays engine.)
Section | ||||||||||||||||||||||
Disk Caching
