his This page provides information on the Configuration settings rollout in V-Ray for SketchUp.
The Configuration rollout is where you can globally configure the Properties display of newly created assets as well as of already existing ones.
The Properties of some rollouts in the V-Ray Asset Editor are organized in Basic and Advanced modes. You can set the mode for all assets, which affects the state of newly created assets and pre-existing ones, or for newly created assets only.
UI Path
||V-Ray Asset Editor|| > Settings > Configuration
Configuration
width65%60%
UI Current ThemeChanges the Color Theme of the V-Ray Asset Editor, Export V-Ray Proxy, V-Ray Color Picker, V-Ray File Path Editor, About Chaos V-Ray, V-Ray Light Gen, and Export V-Ray Scene. You can choose between a Chaos Black (default) theme, a Dark theme, or Bright theme. See the images on the right.
Sliders Color SpaceControls the color space of all Color Picker sliders. Color Picker slider inputs can work with both Rendering (RGB) and Screen (sRGB) values. Selecting the preferred color space affects all color sliders at once.
Rendering (RGB) – The default mode. The color values that are displayed match the color values that V-Ray uses for internal calculations (and the values listed in a .vrscene). This means that if a 0.5 in value, gray color is selected, it appears bright when rendered and viewed in sRGB space. On the other hand, if two colors are blended with a Mix (Map) Layered texture using the same 0.5 mix color, the result is exactly 50% color blend. This mode is useful when blending materials or textures with exact color values. It also allows for specifying exact (might be measured) material albedo, reflection, or transmission.
Screen (sRGB) – The color values that are displayed match the color in the rendered image viewed in sRGB space (the VFB default behavior). This means that if a color is set with exact R G B values, rendered, and then picked from the image the values match.
GPU Preview Devices Selects the devices used for the GPU preview. Note that the selected option is preserved between sessions.
Order Assets – Order assets in the Asset Editor - By Type And Name or By Name.
Delete Confirmation – Enables a confirmation dialog on every asset deletion or purge.
Update Notifications Automatically checks for software updates and enables pop-up notifications. Keep this option enabled to get notified every time a new V-Ray version becomes available.
Properties LevelSets a default level of expertise for newly created assets. This option does not affect pre-existing assets.
Basic – Allows configuration of the essential settings only.
Advanced – Allows configuration of all available settings.
Apply to Existing Applies the default level of expertise to all existing scene assets.
width5%
width30%35%
Image RemovedImage AddedImage Removed
Image Added
Usage Statistics
width60%
Participate in the improvement decisions for future versions of V-Ray by automatically sending and usage statistics to Chaos. No intelligence property is violated when agreeing to participate in the feedback program. Chaos does not gather scenes, assets, materials, etc.
Send anonymous usage statistics to Chaos. Note that no personally identifiable information is collected – Includes the most used product functionality and/or parameter values. The data is not personally identifiable and is not tied to the user's individual account.
Send personalized usage statistics to Chaos – Includes the most used product functionality and/or parameter values, but also contains personally identifiable information tied to an individual user's license. This helps Chaos tailor and optimize the product for better personal use.
width5%
width35%
