Render Parameters rollout of the Settings tab exposes several options that control the Progressive or Bucket image samplers. You can also select an Antialiasing Filter and find a number of Optimization settings here. Note that the exposed controls vary depending on the combination of selections between CPU/GPU, Interactive/Production, and Progressive/Bucket options. Changing the Quality preset from the Render rollout sets a number of options with appropriate values for the selected preset. Generally, the Quality presets will work for a wide variety of scenes and you do not need to adjust the settings any further.
Quality
Section | |||||||||||||||
Interactive Parameters
Antialiasing Filter
Anchor | ||||
Color Management
UI Text Box | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
ACES is the Academy Color Encoding System and developed by the Academy of Motion Picture Arts and Sciences. ACEScg is the version of the ACES encoding system for computer graphics, widely adopted in the industry. It has become the industry standard, because compared to sRGB, ACEScg works with a lot more color information, illustrated in this gamut graph. To see ACEScg setup in V-Ray for SketchUp, expand below.
Optimizations
Switches
V-Ray GPU
