The V-Ray installation includes a standalone denoising tool called vdenoise that can be used to denoise still images or animations outside of V-Ray for SketchUp. This is especially useful for animations because the standalone tool can assess multiple frames at once and produce a better denoising result. The vdenoise tool works with either .vrimg or multichannel OpenEXR files and writes out files with the same format.
UI Path
Section |
||Extenssions|| > V-Ray > Tools > External > V-Ray Denoiser |
Installation
The vdenoise tool is a part of the V-Ray for SketchUp installation pack. You can quickly open a command prompt in the folder where the vdenoise tool is located, or run the executable to bring out vdenoise's GUI.
Windows | C:\Program Files\Chaos\V-Ray\V-Ray for SketchUp\extension\vray\bin\vdenoise.exe |
macOS | /Applications/Chaos/V-Ray/V-Ray for SketchUp/extension/vray/bin/vdenoise.bin |
UI Text Box | ||
For versions prior to V-Ray 7, the default locations are: Windows: C:\Program Files\Chaos Group\V-Ray\V-Ray for SketchUp\extension\vrayappsdk\ |
binmacOS macOS |
: /Applications/ChaosGroup/V-Ray/V-Ray\ for\ SketchUp/extension/vrayappsdk/bin/vdenoise.bin |
Generating the Needed Render Elements
The denoiser needs several render elements in order to work optimally. The easiest way to generate these render elements is to add the VRayDenoiser Render Element to your SketchUp scene.
Excerpt Include | ||||||
Offsetting the Denoiser Output
-frames=0-20 -outputOffset=-4
