Section | |||||||||||||||||||
Why V-Ray GPU?
V-Ray GPU has a number of advantages:
Fancy Bullets | ||
UI Text Box | ||
Тo use NVLINK on supported hardware, NVLINK devices must be set to TCC mode. This is recommended for Pascal, Volta and Turning-based Quadro models. For GeForce RTX cards, a SLI setup is sufficient. Also note that to prevent performance loss, not all data is shared between devices. For more information, see the OptiX and NVLink FAQ page. |
UI Text Box | ||
The RTX engine type only works with NVidia RTX cards. |
Choosing Which Devices to Use for Rendering
UI Text Box | ||
If you see your CPU listed twice, choose the option with "C++/CPU " in the name. |
Hybrid Rendering with CPUs and the
GPU Engine
Starting in 3.60, V-Ray GPU can perform hybrid rendering with the CUDA GPU engine utilizing both the CPU and NVIDIA GPUs. V-Ray can now execute the CUDA GPU source on the CPU, as though the CPU was another CUDA GPU device. To enable the hybrid rendering mode, simply enable the the C++/CPU device device from the list of CUDA devicesGPU devices. You can specify whether the GPU engine uses CUDA or RTX cards.
The hybrid rendering mode does not require any special drivers. Furthermore, you can use the CPU as a CUDA GPU device even if you don't have an NVIDIA GPU and/or NVIDIA drivers installed. Meaning, this mode can be used on computers that don't even have GPUs. The hybrid render engine running on a CPU supports the same features as as the regular V-Ray GPU CUDA engine.
More info about the nature of Hybrid rendering is available at the blog post Understanding V-Ray Hybrid rendering.
