width60%
V-Ray includes a menu with easy shortcuts to some of the most commonly used V-Ray components.
The menu consists of the following submenus: Asset Editor, Chaos Cloud Collaboration, Chaos Cosmos, File Path Editor, Frame Buffer, Light Gen, Rendering, Lights Lights, Objects, Tools, Preferences, Pack Project, and Help.
width5%
width35%
Image RemovedImage Added
V-Ray Menu
width60%
MenuDescription
Asset EditorOpens the V-Ray Asset Editor.
Chaos Cloud CollaborationOpens the Chaos Cloud Collaboration window.
Chaos CosmosOpens the Chaos Cosmos Browser.
File Path EditorOpens the V-Ray File Path Editor.
Frame BufferOpens the V-Ray Frame Buffer.
Light GenOpens the V-Ray Light Gen.
RenderingOpens the Rendering submenu.
LightsOpens the Lights submenu.
Objects
Anchor
4
4
Opens the Objects submenu.
ToolsOpens the Tools submenu.
PreferencesOpens the Preferences submenu..
Pack Project1 2Allows you to create a Zip file that contains the project file and all the associated assets used in the file (textures, environment maps, proxies, linked blocks and their assets, etc).
HelpOpens the Help menu.
width5%
width35%
This submenu contains shortcuts for creating Geometry objects in V-Ray.
width60%
Menu
Description
Infinite Plane
Creates an Infinite Plane.
Export Proxy
Exports a Proxy object.
Import Proxy or VRScene
Imports a Proxy object or a .vrscene file into the scene.
Add Fur to Selection
Creates a Fur Object. Specify an object in the viewport that the fur will be applied to.
Convert to Clipper
Creates a Mesh Clipper plane.
Add Displacement to SelectionAdds Displacement to selection.
Convert to Scatter Host
Converts selected objects to Scatter hosts.
DecalCreates Decal that projects one material on top of another.
Convert to EnmeshCreates an Enmesh surface object.
width5%
width35%
This submenu contains shortcuts for additional Tool functions.
width60%
Menu
Description
Camera Focus Tool
Sets camera focus distance based on a point in the model.
Guess Lens Shift
V-Ray will guess the amount of lens shift that has occurred. Note that it is not usable in any default orthogonal view.
Toggle Camera LockLocks camera position and orientation during Interactive Rendering.
Randomize Object IDs
Randomizes the Object IDs for the selected objects.
Convert Rhino Material
Converts Rhino materials to V-Ray materials.
Randomize Material ID Colors 3
Iterates through all V-Ray materials in the project and for each one assigns a randomly generated color to its ID color parameter.
Apply Enscape Settings
Synchronizes Enscape’s environment and illumination - Sunlight, Sky, and Camera exposure settings with V-Ray's.
External
Opens the external submenu.
width5%
width35%
External Submenu
width60%
Menu
Description
GPU Device Selection
Opens the GPU Selection menu.
V-Ray DenoiserOpens the V-Ray denoising tool.
VRMesh ViewerOpens the V-Ray Mesh Viewer.
width5%
width35%
This submenu contains shortcuts for additional Help.
width60%
Menu
Description
Brings you to the Chaos Group Online help site.
About V-Ray
Shows you Opens the About Chaos V-Ray window where you can find information about the installed version. It The window also includes links to Chaos website, and information about the V-Ray Asset Editor Session Log, EULA, Chaos Global Privacy Policy and Copyright notices.
License
Allows you to open the Online license server and to release your license.
Release V-Ray LicenseReleases all V-Ray Licenses.
License ServerLoads the V-Ray Online License Server configuration page in the web browser.
width5%
width35%
About Chaos V-Ray
width60%
The About Chaos V-Ray window is accessible from V-Ray menu > Help > About V-Ray.
The windows shows information about the installed V-Ray version. It also provides links to the following:
Fancy Bullets
typecircle
width5%
width35%
Image Added
Footnotes
  1. Anchor
    1
    1
    With V-Ray 5 for Rhino, the Zip file created via the Pack Project option includes not only the project file and its V-Ray associated assets but also all native Rhino bitmap textures used in the project file.
  2. Anchor
    2
    2
     When you use the Pack Project option, a pop-up message appears that asks you whether or not to pack Cosmos asset files with the project.
  3. Anchor
    3
    3
     The 'Set Material ID Colors to Black' option is removed from the V-Ray menu, but this workflow is still possible when using the command _vraySetMtlID.
