vray Command | Description | ||||||
vrayBatchRender | Activates the Batch render tool. | ||||||
vrayCamFocus | Activates the camera focus distance tool. | ||||||
vrayCamGuessVertical | V-Ray guesses the amount of lens shift that has occurred and compensates it accordingly. Note that this command is not usable in any default orthogonal view. | ||||||
vrayChangeDefaultScene1 | Allows setting up the default V-Ray options based on the type of project - studio for product design or exterior for architectural visualization. | ||||||
vrayDisplacement | Create=0 Creates a new displacement asset and applies it to the currently selected object. | ||||||
Apply=1 Applies an existing displacement asset to the currently selected object. | |||||||
Remove=2 Removes the displacement from the currently selected object. | |||||||
vrayClipper | Create=0: Creates a Clipper. | ||||||
Apply=1: A pop-up window prompts you to apply an existing Clipper. | |||||||
Remove=2: Removes and existing Clipper. | |||||||
vrayEdit | Allows you to select and edit any asset in the scene. | ||||||
Materials - toggle, default = true. Allows selecting materials in NeUI based on the current selection in Rhino. | |||||||
Objects - toggle, default = true. Allows selecting geometries in NeUI (fur, clipper, lights, etc..) based on the current selection in Rhino. | |||||||
Select - list. Selection filter based on the current selection in Rhino and the Materials and Objects toggles. All - default. Selects all assets that will be acquired from the selection. | |||||||
vrayEditMtl |
Lets you select an object in the scene, whose material to edit. | ||||||
vrayExportVRScene | Exports the current scene into a .vrscene file. | ||||||
StripPaths=on/off – When enabled, all file paths of the assets in the vrscene are stripped down to file names. Conversion of the paths from absolute to relative allows safe vrscene transfer, as long as its asset files are moved to the same directory. | |||||||
HexArrays=on/off – Compresses geometry data in binary form to reduce its size, so it is preserved without any chance of round off errors. | |||||||
HexTransforms=on/off – Compresses object transformation data in binary form to reduce its size, so it is preserved without any chance of round off errors. | |||||||
vrayFur | Create=0: Creates and applies V-Ray Fur to the selected object. | ||||||
Apply=1: Adds an already created V-Ray Fur from a pop-up window to a selected object. | |||||||
Remove=2: Removes an existing V-Ray fur form a selected object. | |||||||
vrayImportMaterial | Imports .vrmat assets. | ||||||
vrayInfinitePlane | Creates a V-Ray Infinite Plane. | ||||||
vrayLightDome | AtPoint=0: Creates a V-Ray Dome Light in a specified point and prompts you to choose an HDRI file.To directly input texture file path without invoking a file-picker window execute the command silently. | ||||||
AsSphere=1: Creates V-Ray Dome Light as a sphere in a specified point and prompts you to choose an HDRI file. To directly input texture file path without invoking a file-picker window execute the command silently. (e.g _-vrayLightDome 0 0,0,0 "C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\RhinoDefault.exr") | |||||||
vrayLightIES | Creates an IES light in the viewport and loads an .ies file of your choice. | ||||||
vrayLightMesh | Create=0: Creates a Mesh Light. | ||||||
Apply=1: Applies a Mesh Light to a selection. | |||||||
Remove=2: Removes Mesh light properties from a selection. | |||||||
vrayLightSphere | Lets you create a sphere light with a scale of your choice. | ||||||
vrayLightSunFromDirect | Converts a directional light into a Sun light. | ||||||
vrayLockCamOrientation | Locks camera position and orientation during Interactive Rendering. | ||||||
vrayLoadSettings | File=0: Loads a .vropt file with render settings. | ||||||
DefaultProduct=1: Loads a default .vropt file. You can choose between the default settings or a custom file. | |||||||
vrayMtlFromRhino | Converts Rhino materials applied to selected objects into V-Ray materials. | ||||||
vrayProxyExport | Exports a geometry as .vrmesh file and shows the Export Proxy window. | ||||||
vrayProxyImport | Lets you import a .vrmesh or .abc file into the scene. | ||||||
vrayRender | Production=0: Starts a Production render and displays the VFB. | ||||||
Interactive=1: Starts an Interactive render. If it is rendering, stops the render. | |||||||
Cloud=2: Starts a Render on the Cloud. | |||||||
Last=3: Starts rendering in accordance with the last type of render used. | |||||||
Stop=4: Stops the current render process. | |||||||
Sync=5: Starts a Production render and can not be stopped from the command line. (it will block the UI until the rendering is over) | |||||||
vrayRenderWindow2 | Similar to RenderWindow, RenderInWindow, and RenderBlowup commands, but ituses the Render Output settings as basis for region calculations instead. The region is specified in absolute image coordinates of its upper-left and lower-right corners. Manually drawing regions in the viewport is also supported. Region=0: Renders a region of the image in the VFB. The specified region matches a manual-drawn region in the VFB, masking out the rest of the image. The masked out region appears black. This mode is suitable for image compositing. CroppedRegion=1: Renders a region of the image in the VFB. The specified region matches a manual-drawn region in the VFB, cutting out the rest of the image. CropRegionBlowup=2: Renders a region of the image in the VFB. The specified region matches a manual-drawn region in the VFB, cutting out the rest of the image. The image height is altered so that the image aspect ratio matches the region aspect ratio, and the region width is scaled up to match the image width. | ||||||
vrayScatter | Used for scattering either real or proxy geometry. It has create, apply, and remove options: Create = 0: Converts objects to Scatter hosts. Object type can be surface, polysurface, mesh and extrusion, excluding InfinitePlane and Proxy special object type. If the selected objects are special objects, the tag is detached. A new Scatter object is created in NeUI and its tag is attached to the selected geometry. Apply = 1: Applies the Scatter modifier to the selected objects. Enter or select the name of one of the Scatter objects available in the scene. Remove = 2: Removes the Scatter modifier from the selected objects. Detaches the special object tag from the Scatter Host surface. | ||||||
vraySelID | Selects object by given ID value. | ||||||
vraySetMtlID | Random=0: Sets random colors as materials IDs to the select objects. | ||||||
Black=1: Sets the selected objects' material ID color to black. | |||||||
vraySetObjectID | Number=0: Sets an integer value as an object ID of the current selection. | ||||||
Random=1: Sets random ID for each selected object. | |||||||
vrayShowAssetEditor | Opens the Asset Editor. | ||||||
vrayShowFilePathEditor | Opens the File Path Editor. | ||||||
vrayShowVFB | Opens the V-Ray Frame Buffer. | ||||||
vrayShowVFBonRender | No=0: Hides the VFB when rendering. | ||||||
Yes=1: Shows the VFB when rendering. | |||||||
vrayVPRSettings | Changes the viewport size. | ||||||
vrayRecordAnimation | In Rhino 5, V-Ray Next automatically acquires animation data from Rhino. This command is useful only for choosing a Rhino animation over a previously set V-Ray Timeline animation in Grasshopper (via the Render in Project component). Creates a TexSky in the Environment map slot (automatically set to Rhino Document sun). Synchronizes V-Ray's environment with the current Rhino environment. In Rhino 6, the command is replaced by the Animation Source option as the animation does not need to be pre-recorded. | ||||||
vrayVantage | Opens V-Ray Vantage. | ||||||
vrayShowCosmos | Opens the Chaos Cosmos Browser. | ||||||
vrayCosmos | Chaos Cosmos delivers a 3D content library with hundreds of high-quality models, materials, and HDRI skies that work seamlessly with both V-Ray and Vision engines. Browser = 0: Opens the Chaos Cosmos Browser. Import = 1: Loads a specific Cosmos asset based on its name or package ID into the current project. If multiple versions of the asset exist, the unique Revision IDs can be used to differentiate between each one. Update = 2: Select a Cosmos asset based on its name or package ID to be updated to its latest version. If multiple versions of the asset exist, the unique Revision IDs can be used to differentiate between each one. Download = 3: Download a Cosmos asset specified by its name or package ID. If a multiple versions of the asset package exist and a specific one is needed, it can be targeted by using the Revision ID. Status = 4: Prints the status of the Chaos Cosmos Browser (connected / disconnected). Disconnect/Connect = 5: Disconnects/Connects the Chaos Cosmos Browser app. | ||||||
vrayEnscape | Renderable=on/off - Enables the support for Enscape materials and assets. When disabled, Enscape data in the scene will be ignored. |
1 – The default preset used is the Studio one and it remains the same unless changed to ArchVis. These presets do not affect the render quality presets. Anchor ArchVis ArchVis
