Section | |||||||||||||||
UI
Paths
||V-Ray Asset Editor|| > > Materials (right-click) > Override
||V-Ray Asset Editor|| > Materials Create Asset (left-click) > Materials > Override
Anchor | ||||
Example: Using the GI Material Override
This example shows how the use of a GI material override affects the rendering. The first scene is rendered with two VRay materials. The second scene is rendered with 1 Base + 1 GI Mtl.
Section | ||||||||||||||||||||||||||||||||||
This simple interior scene represents a room lit by two rectangle VRayLights - one hidden top light and another back fill light - as well as by three disc VRayLights for the pendant lamps above the sinks.
A wooden Generic material from the Chaos Cosmos library is applied on the floor, and a default Generic material with Diffuse Color (128, 128, 128) is applied on the rest of the scene objects, except for the glass objects (mirror and pendant lamp plafonds).
In the first
image, it is
visible that all
walls,
objects, and the
ceiling are rendered in some light brown
color,
despite having a light-gray material assigned to them. This is due to
the color bleeding, generated by
the GI calculations.
In the second
image, the scene is rendered
with an Override V-Ray
material containing the wooden Generic material as a base and the default Generic material plugged into the GI slot. The rest of the scene objects keep the default gray Generic material. So now V-Ray knows that while calculating the GI it has to use the material used as GI override (in this case: Generic with Diffuse color (128, 128, 128) and during rendering it uses the Base material (in this case: the wooden Generic ). The result of that is quite different from the previous render as the Color Bleeding is gone. Of course this depends entirely on
your choice for
the GI material override. For instance, if
you had chosen a bluish colored material, the final result would also be tinted slightly to blue, like in the first render with the pale brown colors
For a much more complex scene, with lots of different geometry, shaders, textures, etc., using
the V-Ray Override material can be very helpful.
Anchor | ||||
Example: Using the Reflect Material Override
The scene used in the following examples is very simple. It contains four boxes, a light source, and a studio type environment. Each box has a MtlOverride material an Override material assigned, but only the Base Material is active. The rendered boxes are all one and the same in their diffuse and their reflections as well. As you can see now, each of the boxes has a different material assigned in their Override Reflect Material. The first one has a red diffuse color, the second one have green, and the third one has blue. V-Ray uses those materials when the objects are seen in reflections. In our scene, the environment is actually a reflective surface, so the boxes are being reflected. On the other hand, you can also notice that the base material of the boxes is also reflective (Fresnel type), and the middle boxes are seen with their Override Reflect material in the right box.
Anchor | ||||
Example: Using the Refract Material Override
The next render is even more complex as the Override Refract Material of the boxes is activated as well. From left to right follow: a cyan, a purple and a yellow diffuse color. Those materials are set so that when seen through refraction, V-Ray will consider and render the objects with them. As you can see the Reflect materials are still affecting the render image. If you take a closer look at the lens' edges you will notice the green reflection, which is actually the reflect material of the middle boxes. While V-Ray had been tracing the rays on the lens' surfaces, those polygons on the edges had first captured a reflection, so that's why there are green traces.
