This section contains links to Geometry objects and tools in V-Ray for Rhino.
V-Ray for Rhino adds a number of geometry objects and tools for use with V-Ray. See the links below for more information.
Each of the V-Ray geometry types has its respective icon. Clipper and Fur can be turned off/on by clicking on their respective icons.
UI Paths
width5%
width50%35%
||V-Ray Asset Editor|| > Geometry (right-click)
||V-Ray Asset Editor|| > Create Asset (left-click) > Geometries
Image RemovedImage Added
width5%20%
width35%
||V-Ray Objects Toolbar|| > V-Ray Objects
Rhino Menus Ribbon
||V-Ray|| menu > Objects
UI Text Box
typenote
Creating a geometry item from the Asset Editor automatically creates it into the viewport with (0, 0, 0) coordinates.
UI Text Box
typetip
Creation of geometry is available from two places in the Asset Editor: the Create Asset button and the Geometry category icon (top). If the Geometry category is empty, left-clicking the icon prompts you to create a new asset. Otherwise, it selects the category in which case, right-click opens the creation menu.
The Asset creation dropdown lists remain active when the Ctrl key is held, allowing the creation of multiple assets in quick succession. The Asset creation dropdown lists can be activated via the Create Asset button or the Asset Category icons.
width5%
Virtual Geometry
Anchor
VirtualGeometry
VirtualGeometry
Responsivegridmacro
VAlignmentstart
Columns2repeat(2, 1fr)
Columns3width1100px
Columns1repeat(3, 1fr)
Columns1width1740px
Columnsrepeat(4, 1fr)
Columns2width1290px
Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
alignleft
classdashboard
Textboxcard
PageToIncludeSystem Requirements
CardPageLinkClipper
Clipper
The Clipper is a virtual plane for clipping geometry at render time.
Textboxcard
CardPageLinkDisplacement
Displacement
Displacement mapping is a technique for adding detail to your scene geometry without having to model it first.
Textboxcard
CardPageLinkFur
Fur
The Fur option creates a simple procedural fur at render time.
Textboxcard
CardPageLinkInfinite Plane
Infinite Plane
The Infinite Plane is a virtual plane that always extends beyond the camera view.
Textboxcard
CardPageLinkProxy Mesh
Proxy Mesh
The Proxy Mesh imports geometry from an external mesh, which only loads the full details at render time. The geometry is not present in the scene and does not take any resources.
Textboxcard
CardPageLinkProxy Scene
Proxy Scene
The Proxy Scene imports a .vrscene file as a proxy, which is fully loaded only at render time.
Textboxcard
CardPageLinkV-Ray Scene Importer
The V-Ray Scene Importer is a tool that lets you import a .vrscene file directly as a Rhino editable file.
Textboxcard
CardPageLinkScatter
Scatter
The V-Ray Scatter creates instances of objects using the surface of another objects to generate points.
Textboxcard
CardPageLinkDecal
Decal
The V-Ray Decal provides an easy way to project one material on top of another regardless of the target UV set.
Textboxcard
CardPageLinkEnmesh
Enmesh
The V-Ray Enmesh modifier 'coats' an object's surface with a repeating pattern of a rendered geometry that follows the UVW placement of that geometry.
Textboxcard
CardPageLinkGaussian Splat
Gaussian Splat
3D Gaussian Splatting is a method used to create a 3D scene from images or videos.
Fancy Bullets
typecircle
  • A Reset option is provided in the context menu of each Number Slider. You can reset the slider value to the default one.
  • Most numeric V-Ray parameters come with a slider to make fine-tuning easier. Each slider is set to a default range of recommended or commonly used values. If a value above that range is used the slider adapts by increasing its range accordingly (2x the input value) to maintain usability. If a value below the current slider range is used, the slider again adjusts its range by shrinking it to twice the amount of the input value.
  • The slider range does not indicate the parameter's total minimum and maximum input values. The absolute minimum and maximum values of each parameter can be found by hovering over its spinbox.
  • Memory usage can be viewed from the Stats section of the new V-Ray Frame Buffer.
  • Starting with V-Ray 5.20.01, V-Ray special objects (Fur/Clipper/Displacement/Mesh Light/Scatter/Decal) are not deleted from the Asset Editor, when the last item with the corresponding special object assigned to it, is deleted from the viewport.
