Once you've carefully read the License Agreement, you can click I Agree if you agree to the terms.
width
5%
width
35%
UI Step
width
60%
Host App Version
This screen allows you to select which Rhino version to install V-Ray for. You can also select more than one version at once.
Proceed to click the Install button.
If you need to customize your V-Ray installation, click the Advanced Advanced button.
width
5%
width
35%
UI Step
width
60%
Advanced Installation
The Advanced Installation button takes you to the Additional Components screen. Here, you can choose whether to install the License Server or V-Ray Swarm and specify the License server machine.
Check the Help us improve V-Ray for Rhino to help with software improvement. For more information on statistics data collection, visit the Chaos Telemetry page.
Click the Continue button to proceed with the installation.
width
5%
width
35%
UI Step
width
60%
Licensing
In this step, you can specify whether the V-Ray license server runs locally or on another machine.
Fancy Bullets
type
circle
If you select theLocallicensing option, you need to install the License Server on your machine.See theChaos License Quick Start Guidefor a walkthrough.
If you select theRemoteoption, you have to fill in the IP address of your V-Ray license server in the fieldPrimary License Server. Please leave the port30304unchanged. AnAlternate License Serveris used when the primary one does not respond.
