This page provides information about the navigation controls in Chaos Vantage.
There are various controls to enableVarious controls allow you to navigate the scene in Chaos Vantage's viewport. Some controls are enabled entirely with the mouse, others with the keyboard, or with combinations between the two. The navigation and some use a combination of both. Navigation can be set to work as in 3ds Max, SketchUp, or Maya. A full full list of shortcuts can be found in is available under Edit > Mouse and Key shortcuts. See the Shortcuts page for more details.
To understand the controls, you should assume refer to the following abbreviations:
Abbreviation | Icon | Control |
LMB | Left Mouse Button | |
RMB | Right Mouse Button | |
MMB | Middle Mouse Button |
Commands
The following commands are universal for all navigation presets:
Shortcut | Command |
Ctrl+Alt+LMB | Change Focus Distance |
Ctr+MMB | Roll Camera |
` | Toggle First Person Mode |
C | Toggle Camera Collision |
Alt+Z | Undo Camera |
Alt+Shift+Z | Redo Camera |
X | Level the Camera and resets Camera roll |
Home | Switch to Home Camera |
PgDown | Switch to Next Camera |
PgUp | Switch to Previous Camera |
Ctrl+F1..F12 | Save Camera Slot |
F1..F12 | Load Camera Slot |
In Fist Person mode | |
W | Camera Move Forward |
S | Camera Move Backward |
A | Camera Move Left |
D | Camera Move Right |
E | Camera Move Up |
Q | Camera Move Down |
Shift+ | Camera Move Faster |
Ctrl+ | Camera Ignore Collisions |
RMB+Mouse wheel | Increase/Decrease Move Speed |
In Edit mode | |
RMB+W | Camera Move Forward |
RMB+S | Camera Move Backward |
RMB+A | Camera Move Left |
RMB+D | Camera Move Right |
RMB+Up | Camera Pan Up |
RMB+Down | Camera Pan Down |
RMB+Left | Camera Pan Left |
RMB+Right | Camera Pan Right |
RMB+Shift+ | Camera Move Faster |
RMB+Ctrl+ | Camera Ignore Collisions |
The following commands have different shortcuts depending on the selected preset:
Tabs Container | |||||||||||||||||||||||||||||||||||||||||||||
