This page describes how to set up your local system so that it loads the files for the correct V-Ray version.
UI Text Box | |||||
Since V-Ray 6, update 1 the Portable installation replaces the .zip builds. See the Portable installation page for more. |
UI Expand | ||||
| Make sure to always have the latest Cinema 4D updates for V-Ray to load.||||
OverviewInstalling V-Ray for Cinema 4D from a .zip file provides the advantage of easy setup and flexible folder management. When installing V-Ray for Cinema 4D from a .zip file, note that Chaos Cosmos is not included by default in the installation. To add it, you can separately download and install it |
. Note also that the EULA is not automatically accepted when installing from a .zip file. A window pops up, when V-Ray is first initiated in Cinema, which prompts you to accept the End User License Agreement.
Required Steps
