Distributed Rendering Settings
For information on Distributed rendering settings in Cinema 4D, please see the Common tab page.
The complete setup follows the these steps:
- Install only the Standalone version of V-Ray for Cinema 4D on each render server machine.
- Start the Installer and choose the Advanced option. Select the Standalone option as shown in the screenshot.
Tabs Container | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Depending on your OS, the vraydr_check executable is located as follows:
Windows – Start Menu > All Programs > Chaos Group > V-Ray for Cinema 4D 4D nn > Tools or alternatively start the .exe in a command-prompt from Cfrom C:\Program Files\Chaos Group\V-Ray\Cinema 4D 4D nnnn\bin
Note: nn is nn is the Cinema 4D version
Usage:
Note: IP is the IP address of the machine that is running a V-Ray render server and num is the number of the port (by default it's 20207). Example: vraydr_check -host=10.0.0.100 -port=20207
Return values:
Fancy Bullets | ||
In case a connection cannot be established with the server, the tool will print prints this message: Failed to connect to server 1.0.0.100:20207
