changes.mady.by.user Gergana Lilkova
Saved on Feb 02, 2024
Saved on Mar 11, 2024
The Coat Reflection Render Element is analogous to the Reflection Render Element.
The Coat Reflection RE stores reflection information calculated from the materials' coat layer. Surfaces with the Coat Amount parameter set to 0 contain no information in the render pass and therefore render as black.
UI Path: ||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > V-Ray Coat Reflection (RE)
