width60%
The Sheen Reflection Render Element (RE) is analogous to the Reflection Render Element.
The Sheen Reflection RE stores reflection information calculated from the V-Ray Materials' Sheen Layer. Surfaces with no reflection values set in their materials contain no information in the render pass and therefore render as black.
UI path: ||out Network|| > V-Ray Render Elements node > V-Ray > Render Channel > V-Ray Sheen Reflection (RE)
width5%
width35%
