Div
stylepadding-left: 5px;padding-right: 5px;padding-bottom: 10px;
classdashboard
Textboxcard
PageToIncludeGetting Started
CardPageLinkV-Ray Particles
V-Ray Particles
Shades X-Particles, ThinkingParticles, and Matrix object.
Textboxcard
PageToIncludeSystem Requirements
CardPageLinkVRayProxy
V-Ray Proxy
Allows an external mesh to be imported at render time only.
Textboxcard
CardPageLinkGeometry Tag
Geometry Tag
Provides control over displacement, subdivision, and OpenSubdiv.
Textboxcard
PageToIncludeInstallation
CardPageLinkVRayObjectProperties
V-Ray Object Properties
Sets different render settings on a per-object basis.
Textboxcard
CardPageLinkV-Ray Scene
V-Ray Scene
Allows for assets to be shared between all platforms that run V-Ray.
Textboxcard
CardPageLinkV-Ray Fur
V-Ray Fur
Simple procedural fur plugin.
Textboxcard
CardPageLinkV-Ray Clipper
V-Ray Clipper
Geometric primitive that can clip away parts of the scene with a defined geometry or a simple plane.
Textboxcard
CardPageLinkVRayRenderableSpline
Renderable Spline Tag
Allows V-Ray to render splines in Cinema 4D.
Textboxcard
CardPageLinkV-Ray Decal
V-Ray Decal
Geometry that allows you to project one material on top of another regardless of the target UV set.
Textboxcard
CardPageLinkV-Ray Enmesh
V-Ray Enmesh
'Coat' an object’s surface with a repeating pattern of a rendered geometry.
Textboxcard
CardPageLinkV-Ray ParticlesGaussians
V-Ray
Particles
Gaussians
Create realistic environments for your scene using 3D Gaussian SplattingShades X-Particles, ThinkingParticles, and Matrix object.
