changes.mady.by.user Kristin Ivanova
Saved on Mar 10, 2022
Saved on Aug 03, 2022
Allows an external mesh to be imported at render time only.
Provides control over displacement, subdivision and OpenSubdiv.
Sets different render settings on a per-object basis.
V-Ray Scene format allows Allows for assets to be shared between all platforms that run V-Ray.
Simple procedural fur plugin.
Geometric primitive that can clip away parts of the scene with a defined geometry or a simple plane.
Allows V-Ray to render splines in Cinema 4D.
Geometry that allows you to project one material on top of another regardless of the target UV set.
'Coat' an object’s surface with a repeating pattern of a rendered geometry.
Shades X-Particles and ThinkingParticles.
