Build 5.20.06
Official release, update 2.6
Date - Jul 06, 2022
UI Button | ||||||||||
New features
V-Ray
- Implement an option for animating visibility in Object Properties tag
Modified features
V-Ray
- Raise the max file limit on MacOS to improve stability
Bug fixes
V-Ray
- Add support for the Reroute node
- Additional unused nodes in node materials
- Missing Add and Remove layer buttons from the layered node in V-Ray Node material on Cinema4D R26
- The V-Ray Node space is not registered in Cinema 4D S26.1
- Rendering Stereoscopic images in the Picture Viewer with Stereo Camera doesn't work in Cinema 4D S26
- Assigned material part of the compound does not transfer to a new scene
V-Ray GPU
- Texture mapping doesn't work on extruded spline primitives
VRayProxy
- An error message popped up when exported cosmos asset is rendering
Build 5.20.05
Official release, update 2.5
Date – Jun 09, 2022
New features
V-Ray, VRayTextures
- New nodes for context control
Add VRayEdges texture for node and classic materials
Modified features
V-Ray
- Expose the UVWChannel shader for use with Classic materials
- Implement the "Use object material" option for V-Ray Clipper
Official release, update 2.4
Date - Apr 27, 2022
New features
V-Ray
- Support for Cinema 4D S26
- Implement V-Ray Override Material
Bug fixes
V-Ray
- Coat glossiness might produce NaN values in certain scene setups
- Filter shader with empty input exports invalid vrscene
- Fusion shader with empty channel exports invalid vrscene
- Crash when VFB is opened in Cinema 4D R20
- Corrupted node materials when changing versions
Official release, update 2.3
Date - Apr 06, 2022
New features
V-Ray
Implement V-Ray Renderable Spline tag
Support for the Cinema 4D Projector shader
Modified features
V-Ray
Improve export of native Cinema 4D shaders (Fusion, Fresnel and Colorizer)
Improve export of native Cinema 4D material
Support projection of single material with multiple selections
Official release, update 2.2
Date - Feb 16, 2022
Modified features
V-Ray
- Transfer the object hierarchy when exporting vrscene and importing it into Chaos Vantage
Bug fixes
V-Ray
- Scenes with UVW randomizer may crash on open
- Render mask clear does not work in animation or when toggled during interactive
- V-Ray clipper (when mesh is used as a clipper) reduces the quality of the mesh when the objects are scaled down
- Cryptomatte doesn't work with Node Layer name ID type
Official release, update 2.1
Date - Feb 9, 2022
New features
V-Ray
- Implement V-Ray Aerial Perspective
- Implement V-Ray Normal Map shader node
- Add support for the Cinema 4D infinite floor
- Show the ObjectID number as overlay in the Object Properties icon
Modified features
V-Ray
- Update Open Image Denoiser with support for Arm M1
- Ability to create V-Ray Node materials from the menu
- The U and V Size parameter in the light should represent the width and height of the light
- Recalculate the intensity value for V-Ray Lights based on the currently selected light units
Bug fixes
V-Ray
- Support for loading assets from the new asset browser system in Cinema 4D S24 and R25
- V-Ray doesn't respect the viewport aspect ratio and renders cropped image
- Camera Shift causes Viewport Rendering to be mismatched
- Turning ON or OFF the Round Edges doesn't refresh in interactive
- Sun shadow texture is not rendered
Official release, update 1.4
Date - Oct 27, 2021
Bug fixes
V-Ray
- Incorrect texture rendering when the UVW tag is placed after the material tag
- V-Ray Bitmap "No Tiling" option does not work
- Fix broken hyper link inside the Update dialog
Official release, update 1.3
Date - Oct 14, 2021
New features
- Support for Cinema 4D R25
- Support TexRamp in material nodes
Modified features
V-Ray
- Improve responsiveness when working with Node Materials
- Add an option to hide QT framework warnings from the log
- Better conversion for the "Material Weight" and "Use Fresnel" parameters from the classic V-Ray Advanced Material
Bug fixes
V-Ray
- Fix slow export of cloners in render instance mode
- Fix slow export of scenes with lots of material assignments
- GPU device selection is not used if preferences are not open
- Wrong viewport previews of node materials
- Viewport previews don't render if editor map size is not default
- Overridden editor map size in the preview settings of the material is considered even if "override preferences" is disabled
- The "Save" and "Open" dialogs are not shown when the VFB is used on displays with different DPI scaling
- Textures are black in the viewport when using Cinema4D layered shader
- LightMix in manual light select mode does not work
Official release, update 1.2
Date - Sept 02 2021
New features
V-Ray
Support for Chaos Cosmos
Implemented V-Ray Normal Map texture
TexMix as classic shader and node added in the V-Ray node space
Modified features
VRayMaterials
Material viewport previews are slow even for constant colors
Ozone and Turbidity parameters in VRay Sky should be inactive when Sky Model is set to Improved
Bug fixes
V-Ray
Fixed wrong shadows casted by V-Ray Sun to Volumetric objects
Moving the VFB window causes the image inside to flicker
The Vertical Shift parameter in the Physical Camera does not work in Production rendering
Official release, update 1.1
Date - Jul 27 2021
Modified features
V-Ray
- Support for the VertexMap tag
Bug fixes
V-Ray
- V-Ray doesn't render in the same color space as the Node materials
- Geometry dissapears with V-Ray GPU Interactive rendering when using the CUDA engine
- Opacity mask doesn't work if the "Tile" option is disabled
- V-Ray doesn't render motion blur when using command line rendering with frame overrides
- Node preview updates may not be triggered for ports of Layered and Blend nodes
- Aborted update of texture node preview
- Different animated visibility in V-Ray for Cinema 4D and Standalone
- Animated visibility of objects does not work when exported and rendered with V-Ray Standalone
- Fix artifacts with animated boolean geometry
- Crash with animated boolean geometry when using default scene material
Date - Jun 23, 2021
New features
V-Ray
- Add V-Ray node space for node materials
- Add V-Ray Clipper as scene object
- Add V-Ray Fur as scene object
- Cryptomatte in progressive
- Progressive caustics mode
- Added support for normal maps in world space
Modified features
V-Ray
- Improve include/exclude object lists usage with hierarchies
- Consider MotionBlur tag for disabling motion blur on objects
- Faster initialization of meshes with static 3D displacement in Standalone
- Mixed filtering option for ZDepth
- Added preview modes to V-Ray Proxy object
- Automatically load the full geometry when it's made editable
- Add support for dirt and curvature attached to extra tex when OOC geometry is enabled
Bug fixes
V-Ray Proxy
- Fixed export of animated proxy
- Instances and Multi-instances support
- Support blending of multiple material assignment tags
- Motion blur samples override for objects
- Support Cinema 4D S24
Bug fixes
- Hair is rendered without motion blur
- Crash when switching projects with Volume Grid preview in Cinema 4D
- The MultiMatte render element renders different result in V-Ray GPU compared to V-Ray
- V-Ray GPU production crashes if there is applied material with missing texture
- VolumeGrid Preview Rollout for Cinema 4D - Velocity Streamlines
- Integrate V-Ray TexRamp texture
- Support for Cloner object with V-Ray Volume Grid in Cinema 4D
Bug fixes
- Distributed rendering doesn't work correctly when rendering animations
- Wrong material assignment on objects with dynamic caches
- HairNextMtl doesn't work with bitmaps assigned to the diffuse color
- Materials get tiled when scaled even if "tile" setting is disabled in Attributes manager
- Image sequences are not rendered when used with the Cinema 4D bitmap
- Cinema 4D noise doesn't work when used in Blend Material
- Relative file paths do not work for non-texture assets
- Deformed geometry does not update in animation
- Motion blur only works for the first rendered frame
- The Distance texture is not affected by geometry with applied skin deformer
- Crashes on MacOS systems with more CPU cores
- Cloning Proxy objects doesn't copy the assigned materials
- LegacySceneConverter: Support of converting object layers
- LegacySceneConverter: Support for more converted types (Materials and Composite Tag)
- Render Elements: Prevent drag and drop of non-render element objects in the render elements list
- Exported lights should consider visibility and layers flags
- VRayVolumeGrid: VolumeGrid Preview Rollout for Cinema 4D - Container and Voxel Preview
- Ability to convert scenes via script with python (c4dpy)
- Add an option to disable the automatic conversion pop-up window when opening V-Ray 3.7 scene
Bug fixes
- V-Ray doesn't respect the "Render" option in the Cinema 4D layers
- Wrong texture projection of child objects
- Native C4D noise shader doesn't render correctly when rendering with DR
- Missing Phong tags may cause different buckets from slaves with DR
- Wrong UVW coordinates when generated with V-Ray Material
- VRayProxy: Copying Proxy objects doesn't copy the assigned materials
- Displacement is wrongly applied when geometry is cloned
- The "Use mtl ID" parameter in the ObjectSelect RE doesn't work
- Objects saved in the content browser do not show the materials applied to them
- Interactive: Starting Interactive with unsupported camera makes the render buttons inactive
- Interactive: VFB settings and layers are reset when changing material preview scene or creating material
- Exported animation does not have second frame values in vrscene
- Applying material to a poly selection should happen only in "Polygon" mode
- VRayVolumeGrid: When two or more VolumeGrids in Cinema 4D load the same cache, their previews are not updated correctly when scrolling the timeline
- Improve Interactive and UI responsiveness when tweaking materials and textures
- V-Ray GPU: Normal displacement has wrong normals
- V-Ray GPU: Incorrect GPU LPE REs with Light Cache
Beta Release
Date - Sep 28, 2020
New features
Installation
- Integrate the new installer design in V-Ray for Cinema 4D
- Embed the License Server installation in the V-Ray for Cinema 4D installer
V-Ray Denioser
- Added Nvidia AI Denoiser
