This page provides information on the Coat Reflection Render Element.
width
57%
The Coat Reflection Render element is analogous to the Reflection Render Element, with the main difference being that all Coat render elements can be subtracted from the main back-to-beauty composite, graded, and added back in.
The Coat Reflection Render Element stores reflection information calculated from the materials' reflection values reflection values in the scene. Surfaces Surfaces with no reflection values set in their materials will contain no information in the render pass andwill , therefore, render as black.
The Coat Reflection Render Element is formed by multiplying the Raw Coat Reflection Render Element by the Coat Filter Render Element. So, while the raw coat reflection pass gives the full reflection of objects reflecting in the scene, the coat the coat reflection filter sets how much of of that reflection should come through in the composite. The two are multiplied together to create the Coat Reflection pass, which gives a true representation of the reflection in the scene.
UI Path: ||V-Ray|| > Render Elements > Coat Reflection
width
5%
width
38%
Multiexcerpt include
MultiExcerptName
AddBackground
PageWithExcerpt
Atmospheric Effects RE
How to add a render element to a scene
Properties
width
57%
Enable Deep Output – Specifies whether to include this render element in deep images.
Color Mapping – – Applies the color mapping options specified in theColor mappingMapping rollout of the V-Ray tab in the Render Settings window to this render element. This option is enabled by default.
Consider for Anti-Aliasing – When enabled, anti-aliasing is used where possible.
Vfb Color Corrections – – Applies the post-render color adjustments made from the VFB.
