Official release
Date – 23 September, 2020
Download – Build 4.30.00
With Phoenix FD 4.30 we added force tuning to Voxel and Particle Tuners. This allows forces to affect particles or voxels with certain channels, inside or outside geometries, or according to textures, effectively allowing you to mask forces and gain precise control over how, when and where forces affect the simulation.
We sped up our particle preview and added the ability to preview the Rendering Displacement of the particles in the viewport.
Rendering of fire/smoke with the Use Probabilistic Shading option is now much faster with V-Ray 5. Both fire/smoke simulations, as well as large FLIP liquid simulations are also sped up.
We did some more changes to simulations, allowing for more control and quicker iterations, and we also improved our Standalone Preview and Cache Converter tools, so be sure to check them out!
Status
colourGreen
titleNew
Status
titleparticle tuner
 Choose forces to affect the particles when the Tuner condition passes. This allows forces to affect particles with certain channels, inside or outside geometries or according to textures
Status
colourGreen
titleNew
Status
titlevoxel tuner
 Choose forces to affect the voxels when the Tuner condition passes, same as the Particle Tuner
Status
colourGreen
titleNew
Status
titlepreview
 Displace the particle preview in the viewport when Rendering Displacement is enabled
Status
colourGreen
titleNew
Status
titlecache i/o
 Cacheless Simulation option for speeding up large simulations. It keeps in memory only the last simulated frame and GPU Preview images or per-frame renders can be saved
Status
colourYellow
titleImproveD
Status
titleflip Solver
 Now the Wetmap Liquid particles can stick to WetMaps without the need for the Liquid to have viscosity. The strength of the sticky effect now depends only on the Sticky Liquid option value and the WetMap Viscosity - the Liquid Viscosity does not affect it directly anymoreviscosity
Status
colourYellow
titleImproveD
Status
titleflip Solver
 Delete Liquid particles when a Source's Inject Power is negative
Status
colourYellow
titleImproveD
Status
titleflip Solver
 Change the Motion Velocity, Viscosity or RGB of existing Liquid particles with a Source in Volume Brush mode with disabled Emit Liquid
Status
colourYellow
titleImproveD
Status
titleflip Solver
 Reduced the peak memory usage of the FLIP liquid simulations
Status
colourYellow
titleImproveD
Status
titleflip Solver
 Now Liquid particles can stick to WetMaps without the need for the Liquid to have viscosity. The strength of the sticky effect now depends only on the Sticky Liquid value and the WetMap viscosity StatuscolourYellowtitleImproveD
Status
titlegrid Solver
 Sped up the Multi-Pass Transport method with up to 20%
Status
colourYellow
titleImproveD
Status
titlevolume shader
 Sped up rendering of volumes when Use Probabilistic Shading is enabled
Status
colourYellow
titleImproveD
Status
titleparticle shader
 Color Map for the Particle Shader using V-Ray 5 GPU
Status
colourYellow
titleImproveD
Status
titlepreview
 Multithreaded gathering of Particle Preview data
Status
colourYellow
titleImproveD
Status
titlegpu preview
 Show multiple Simulators in the classic GPU Preview, instead of only the selected one
Status
colourYellow
titleImproveD
Status
titlecache i/o
 Sped up grid channel compression when saving AUR from the simulation or cache_converter tool
Status
colourYellow
titleImproveD
Status
titlestandalone preview
 New layout where all panels can be docked, reordered or detached from the main window
Status
colourYellow
titleImproveD
Status
 Added information about the currently loaded path and the date of the cache's last modification
Status
colourYellow
titleImproveD
Status
titlecache converter
 Convert all caches in a folder without specifying frame range
Status
colourYellow
titleImproveD
Status
 Convert VDB to AUR caches
Status
colourYellow
titleImproveD
Status
 Added a -storageQuality optional argument, useful when writing AUR caches
Status
colourYellow
titleImproveD
Status
 Stop the conversion and show a meaningful error message if the Cache Converter can't find its openvdbio.dll
Status
colourYellow
titleImproveD
Status
titleUser Interface
 Stop the simulation with the ESC key or SHIFT + ESC combination
Status
colourRed
titlefixed
Status
titleFLIP Solver
 Newborn Splash particles kept splitting and creating more Splashes underwater
Status
colourRed
titlefixed
Status
titleFLIP Solver
 WetMap's viscosity was ignored by the Sticky Liquids effect when interacting with variable viscosity Liquid particles
Status
colourRed
titlefixed
Status
titleFLIP Solver
 Sticky Liquid's strength did not scale Linearly
Status
colourRed
titlefixed
Status
titleFLIP Solver
 Foam's Half Life deleted different amount of particles when simulating on different number of threads
Status
colourRed
titlefixed
Status
titleFLIP Solver
 Liquid particles got deleted on contact with animated obstacles having only rotation
Status
colourRed
titlefixed
Status
titleFLIP Solver
 A fast moving simulator with Fillup For Ocean had particles created outside the grid, which are then not deleted
Status
colourRed
titlefixed
Status
titlegrid Solver
 Crash on Load & Start with Drag particles with RGB
Status
colourRed
titlefixed
Status
titlesources
 Different amount of Source Particles (Drag/Foam/Splash) was born each new simulation or on different number of simulation threads
Status
colourRed
titlefixed
Status
titlesources
 Sources were emitting up to 50% slower in very high resolution scenes, since Phoenix FD 4.20
Status
colourRed
titlefixed
Status
titleVolume Shader
 Crash when rendering AUR files over 2.1 billion voxels with Linear Sampler
Status
colourRed
titlefixed
Status
titlev-ray ipr
 Random crash in IPR when changing any properties of a Particle Shader
Status
colourRed
titlefixed
Status
titleMesher
 Setting Motion Blur Multiplier for Mesh modes did not affect the inertial velocity of a moving container
Status
colourRed
titlefixed
Status
titleOcean Mesher
 Crash after previewing the ocean mesh in the viewport, deleting the caches, and enabling Pure Ocean
Status
colourRed
titlefixed
Status
titleOcean Mesher
 Underwater Goggles did not render correctly with Motion Blur
Status
colourRed
titlefixed
Status
titleOcean Mesher
 Ocean Mesh mode with any 3ds Max modifiers did not render on V-Ray GPU
Status
colourRed
titlefixed
Status
titlePreview
Status
colourRed
titlefixed
Status
titleCache I/O
 Size of particles simulated to OpenVDB were in voxels instead of units
Status
colourRed
titlefixed
Status
titleCache I/O
 Restoring from VDB causes missing FLIP particles, wrong Initial Fillup, and wrong results with rotating simulators
Status
colourRed
titlefixed
Status
titleCache I/O
 Could not save AUR caches where a single grid channel was over 3.05 GB. AUR files saved after the fix can not be opened with older Phoenix versions
Status
colourRed
titlefixed
Status
titleCache I/O
 Could not read huge particle systems from AUR cache files (with hundreds of millions of particles). New AUR files will not be readable by older Phoenix versions.
Status
colourRed
titlefixed
Status
titleCache I/O
 Rare crash while blending frames including particles with velocity data
Status
colourRed
titlefixed
Status
titleCache I/O
 Rarely caches were loaded with missing horizontal voxel slices, which affected the previews, and rendering of fire/smoke and meshes
Status
colourRed
titlefixed
Status
title3ds max integration
 Phoenix Textures could not be created in the Material Editor or the 3ds Max Map Browser when Arnold was set as current renderer
Status
colourRed
titlefixed
Status
titleStandalone Preview
 After pressing Cancel in the Browse dialog window, the saving path was erased
Status
colourRed
titlefixed
Status
titlevrscenes
 3D texture maps with Object XYZ mapping rendered with wrong scale with V-Ray Standalone on CPU
Status
colourRed
titlefixed
Status
titleuser interface
 Animating any Phoenix curves or color gradients (in Discharge Modifiers, Volumetric Settings and Particle Texture) did not update them when scrolling the timeline
