Section | |||||||||||||||
Layers Menu
Creates a layer. Multiple layers of the same type can be added. Folder - – Allows grouping multiple layers in folders. This is only available when the Source layer is set to Composite; | |
Deletes the selected layer(s). | |
Saves a layer tree preset. | |
Loads a layer tree preset. | |
Quick access to custom layer presets. You must set the path to it in the VFB Settings. | |
Undo various actions related to layers, such as create, delete, reorder, or modify a layer. | |
Redo various actions related to layers, such as create, delete, reorder, or modify a layer. |
Layers can be disabled from the visibility icon (
), reordered, nested, stacked in folders, etc....
UI Text Box | ||
Color corrections and the denoiser channel are saved in the output image just like they are applied in the VFB. Adjustments made to the Display Correction layer are only applied for preview purposes in the VFB. Display corrections are usually saved for 8-bit image formats like JPEG and PNG and not to EXR files, which are expected to be linear. |
Display Correction
Section | |||||||||||||||||||
UI Text Box | ||
The Display Correction layer cannot be removed or reordered. It is always applied |
on top of all |
Blends the FG based on the alpha values of the BG.
other layers, as it specifies the display color space of the resulting image or composite in the frame buffer. |
OpenColorIO (OCIO)
Source
LightMix Mode
Composite Layer Properties
UI Text Box | ||
The Display Correction layer cannot be removed or reordered. It is always applied on top of all other layers, as it specifies the display color space of the resulting image or composite in the frame buffer. |
Blend modes
Source
LightMix Mode
Lens Effects
Background
Constant
Exposure
White Balance
Hue/Saturation
Color Balance
Blend Mode* | Description |
Overwrite | Displays the current layer (FG) on top of all layers (BG) without blending. This is the default. |
Normal | Blends the FG based on the alpha values of the BG. |
Average | The average of the current layer (FG) and the result from the layers below it (BG). |
Add | Adds the FG to the BG. |
Subtract | Subtracts the FG from the BG. |
Divide | Divides the pixel values of the FG by the BG. Dark areas of the render are brightened, while bright areas of the render are not changed significantly. Does not affect completely white areas. |
Darken | Compares the FG to the BG and takes the darker pixel values of the two. |
Multiply | Multiplies the FG by the BG. |
Color Burn | The color of the FG is applied to darker pixels in the BG. |
Linear Burn | Same as Color Burn but with less contrast. |
Lighten | Compares the FG to the BG and takes the lighter of the two. |
Screen | Makes both light and dark areas lighter. |
Pin Light | Replaces the BG colors depending on the brightness of the FG color. If the FG color is lighter than mid-gray, BG colors darker than the FG color are replaced and vice versa. |
Difference | Compares the pixels in the BG and FG and subtracts the darker pixels from the brighter ones. |
Exclusion | Same as Difference but with less contrast. |
Hue | Uses the hue from the FG , while the value and saturation are taken from the BG. |
Saturation | Uses the saturation from the FG, while the value and hue are taken from the BG. |
Color | Uses the hue and saturation from the FG, while the value is taken from the BG. |
Value | Uses the value from the FG, while the hue and saturation are taken from the BG. |
Hard Mix (8bit) | Adds the FG to the BG and for each color component returns a value of 255 if the result is 255 or greater, or returns 0 if the result is less than 255. |
Color Dodge (8bit) | The color of the FG is applied to lighter pixels in the BG. |
Linear Dodge (8bit) | Same as Color Dodge but with less contrast. |
Spotlight (8bit) | Same as Multiply, but with twice the brightness. |
Spotlight Blend (8bit) | Same as Spotlight, but additionally brightens the BG. |
Overlay (8bit) | Darker pixels become darker where the BG is dark and brighter pixels become brighter where the BG is bright. |
Soft Light (8bit) | Darker pixels become darker where the FG is dark and brighter pixels become brighter where the FG is bright. |
Hard Light (8bit) | Spotlight is applied to pixels where the FG is dark and Screen is applied to pixels where the FG is bright. |
Anchor | ||||
Stamp
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Lens Effects
Sharpen/Blur
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Context MenuRight-clicking in the curve view brings up a context menu with additional options: Menu Item | Description | Zoom all | Adjust the curve view so that all points are visible. | Undo/Redo | Undo and redo modifications to the curve. | Load | Load the curve control from a file. Two formats are available: native .bcurve and PhotoShop .acv. | Save | Save the curve control to a file. Two formats are available: native .bcurve and PhotoShop .acv. | Reset Master | Reset the curve control to its default state. | Select internal only | Select only the points which are currently visible in the curve view. | Select all | Select all points. | Snap to grid | Toggle snapping to the curve grid. When enabled, moving points snaps them to the grid nodes. |
Lookup Table
Filmic Tonemap
Denoise
Filmic Tonemap
Lookup Table
Curves
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Color Balance
Hue/Saturation
White Balance
Exposure
Constant
Background
Example: Background
Save your rendering with the uploaded background in the final exported image by enabling the “Save in image” option in the Background layer properties and saving the image as a .jpg file format.
You can easily control the exposure of the background image by changing the “Environment” intensity multiplier of the Light Mix parameters. For this purpose make sure to add a Light Mix render element prior rendering and set the VFB Layers Source to Light Mix.
Before after | ||||||||||
Masks
Proportion Guide
Fancy Bullets | ||
