This page provides information on the Lens Effects layer found in the V-Ray Frame Buffer.
Section | ||||||||||||||||||||||
UI Path
Lens FX controls
Anchor | ||||
Example: Size
Section | ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Anchor | ||||
Anchor | ||||
Example: Intensity
Anchor | ||||
Example: Cold/Warm & Saturation
Aperture Shape
Anchor | ||||
Example: Streak blur
Lens Scratches
Lens Dust
Lens Dust
Obstacle Image
Anchor | ||||
Example: Obstacle Images
Size (constant) = 50
Bloom (constant) = 0.5
Aperture Preview
Chromatic Aberration
Anchor | ||||
Example: Chromatic Aberration Strength
Depending on the Strength of the chromatic aberration, you can create different looks in your scene. You can imitate the effect of a real camera with subtle aberration, or, if you wish to achieve an artistic effect, consider increasing the Strength parameter, as in the example.
Aperture Preview
File Names of Saved Channels
As expected, channels keep their names as displayed in the VFB when saving them to a single .vrimg or .exr file (using the Save all image channels to single file VFB button). The same channel names are appended to the files when you use the VFB button Save all image channels to separate files.
Fancy Bullets | ||
