Processor | minimum: Intel® 64, AMD® 64 or compatible processor with SSE4.2 support; recommended: Intel® 64, AMD® 64 or compatible processor with SSE4.2 support. Larger cache memory, higher memory bandwidth and more cores are better. |
RAM | minimum 8 GB RAM, recommended 16 GB RAM |
Hard Disk Space | minimum 2GB, recommended 12GB (includes additional downloadable content) |
TCP/IP | Only IPv4 is supported. IPv6 is currently not supported |
Operating system | Windows® 8.1, Windows 10, Windows 11 |
Revit | Autodesk Revit 2018, 2019, 2020, 2021, 2022, and 20222023. |
GPU Support | Maxwell-, Pascal-, Turing-, Volta-, or Ampere-based NVIDIA card(s) with latest recommended video driver V-Ray Vision requires a Graphic card with DirectX 11 or DirectX 12 and Shader Model 5.0 capabilities. |
