Processor
minimum: Intel® 64, AMD® 64 or compatible processor with SSE4.2 support;
recommended: Intel® 64, AMD® 64 or compatible processor with SSE4.2 support. Larger cache memory, higher memory bandwidth and more cores are better.
RAM
minimum 8 GB RAM, recommended 16 GB RAM
Hard Disk Space
minimum 2GB, recommended 12GB (includes additional downloadable content)
TCP/IPOnly IPv4 is supported. IPv6 is currently not supported
Operating system
Windows ® 8.1, Windows 10, Windows 11
RevitAutodesk Revit 2018, 2019, 2020, 2021, 2022, and 2023.
GPU Support
Maxwell-, Pascal-, Turing-, Volta-, or Ampere-based NVIDIA NVIDIA card(s) with   latest recommended video driver
V-Ray Vision requires a Graphic card with DirectX 11 or DirectX 12 and Shader Model 5.0 capabilities.
CUDA compute capability and card reference
** Autodesk Revit 2018 is not supported on Windows 11
*** Windows 11 is required for running Intel Alder Lake processors.
