To run V-Ray, you have to:
Progress Bar Container
step1
Progress Bar - Hyperlink Step
titleStep 1: Install V-Ray
url Installation
titleStep 2: Activate your license
urlChaos License Quick Start Guide
titleStep 3: Load V-Ray in Revit
urlLoading V-Ray
width50%
V-Ray installer automatically uninstalls any previous versions. Uninstalling V-Ray from Revit does not uninstall Chaos Cloud Client, Chaos Cosmos Browser, Chaos License Server, Chaos Unified Login and V-Ray Swarm. Those can be uninstalled separately if needed.
This guide is to serve as a reference for installation of V-Ray for Revit.
A complete installation of V-Ray for Revit consists of:
Fancy Bullets
typecircle
  • V-Ray
  • V-Ray License Server
  • V-Ray Swarm
  • Chaos Cloud Client app
  • Chaos Cosmos Browser service
  • Chaos Unified Login
UI Button
colorblue
newWindowtrue
icondownload
titleDownload V-Rat for Revit
urlhttps://download.chaosgroup.com/?license_type=adv&platform=55&platform_version=186&product=47
width10%
width40%
width40%
Installing V-Ray for Revit gives you access to:
Fancy Bullets
typecircle
To start the installation, double-click the installation file. The V-Ray installer automatically removes any previous installations. This allows seamless upgrade from previous versions. If you experience problems, manually uninstall the previous versions to perform a clean install. See the Uninstall V-Ray page for more information.
width60%
Revit VersionInstaller Name
Revit 2025 x64vray_adv_61005_revit_win_x64
Revit 2024 x64vray_adv_61005_revit_win_x64
Revit 2023 x64vray_adv_61005_revit_win_x64
Revit 2022 x64vray_adv_61005_revit_win_x64
Revit 2021 x64vray_adv_61005_revit_win_x64
Revit 2020 x64vray_adv_61005_revit_win_x64
Revit 2019 x64vray_adv_61005_revit_win_x64
width5%
width35%
Running the Installer
UI Steps
UI Step
width60%
End User License Agreement
Once you've carefully read the License Agreement, click I Agree if you agree to the terms.
width5%
width35%
UI Step
width60%
Host App Version
This screen allows you to select which Revit version to install V-Ray for. You can also select more than one version at once.
Proceed to click the Install button.
If you need to customize your V-Ray installation, click the Advanced button.
width5%
width35%
UI Step
width60%
Advanced Installation
The Advanced Installation button takes you to the Additional Components screen. Here, you can choose whether to install the License Server or V-Ray Swarm and specify the License server machine.
Check the Help us improve V-Ray for Revit to help with software improvement. For more information on statistics data collection, visit the Chaos Telemetry page.
Click the Continue button to proceed with the installation.
width5%
width35%
UI Step
width60%
Optimize V-Ray for Revit installation by manually setting the location folder where V-Ray is installed. You can also enable distributed rendering via V-Ray Swarm upon installation. That way, you won't need to enable it from within the V-Ray for Revit UI.
Destination location – Specify an installation location for V-Ray for Revit.
V-Ray Material library – Specify a download location for the Materials Library and Cosmos Assets.
V-Ray Swarm Enabled – When enabled, after the installation is complete, V-Ray Swarm is activated by default.
The settings below become available after checking the V-Ray Swarm Enabled checkbox.
Don't use local machine – When enabled, the local machine is excluded from rendering. However, V-Ray Swarm continues to use a small percentage of the local machine's resources to communicate with the nodes.
Goal – Sets the desired percentage of utilization of available resources. Computers added to or removed from V-Ray Swarm are taken into account automatically.
Auto-Discovery – When enabled, the installation searches for other nodes in the network.
Tags – Tag this node with a descriptor that defines something about the machine and use it for selective control from inside of Revit. Separate each tag by a comma. For more information, check the Swarm page.
width5%
width35%
UI Step
width60%
Licensing
In this step, you can specify whether the V-Ray license server runs locally or on another machine.
Fancy Bullets
typecircle
  • If you select the Local licensing option, you need to install the License Server on your machine. See the Chaos License Quick Start Guide for a walkthrough.
  • If you select the Remote option, you have to fill in the IP address of your V-Ray license server in the field Primary License Server. Please leave the port 30304 unchanged. An Alternate License Server is used when the primary one does not respond.
width5%
width35%
UI Step
width60%
V-Ray installation is successful.
width5%
width35%
Next Step
Go to step 2 to activate your Chaos License.
step1
url Installation
urlLoading V-Ray
