Section | |||||||||||||||||
SHOULDUNINSTALL | Specifies the uninstall type: 0 - Does not uninstall previous installation. 1 - Uninstall previous installation. | ||
STDROOT | Specifies the root Revit folder. The default is C:\Program Files\Chaos Group\V-Ray\V-Ray for Revit | ||
MATERIALS_LIBRARY | Specifies location for the V-Ray material library (the library itself should be downloaded from within the gui after a successful installation). The default location is C:\Users\<username>\Documents\V-Ray Material Library | ||
REVERT_INSTALL | The parameter is used when the installer encounters an error – it triggers uninstallation and removes the files that have been populated before the error appears. Should always be set to its default 1. | ||
INSTALL_REVIT | Specifies the installation type: 0 - Does not install V-Ray for Revit. This is useful when you want to install only V-Ray Swarm, for example. 1 - Installs V-Ray for Revit. | ||
INSTALL_REVIT18 | Specifies the installation of V-Ray for Revit 2018: 0 - Does not install V-Ray for Revit 2018. 1 - Installs V-Ray for Revit. | INSTALL_REVIT19 | Specifies the installation of V-Ray for Revit 2019: 0 - Does not install V-Ray for Revit 2019. 1 - Installs V-Ray for Revit. |
INSTALL_REVIT20 | Specifies the installation of V-Ray for Revit 2020: 0 - Does not install V-Ray for Revit 2020. 1 - Installs V-Ray for Revit. | ||
INSTALL_REVIT21 | Specifies the installation of V-Ray for Revit 2021: 0 - Does not install V-Ray for Revit 2021. 1 - Installs V-Ray for Revit. | ||
INSTALL_REVIT22 | Specifies the installation of V-Ray for Revit 2022: 0 - Does not install V-Ray for Revit 2022. 1 - Installs V-Ray for Revit. | ||
INSTALL_REVIT23 | Specifies the installation of V-Ray for Revit 2023: 0 - Does not install V-Ray for Revit 2023. 1 - Installs V-Ray for Revit. | ||
REVITROOT | Specifies the root Revit folder. The default folder is C:\ProgramData | ||
REVIT_EXE_ | ROOT18Specifies the folder location for the Revit 2018 .EXE file. The default is C:\Program Files\Autodesk\Revit 2018 | REVIT_EXE_ROOT19 | Specifies the folder location for the Revit 2019 .EXE file. The default is C:\Program Files\Autodesk\Revit 2019 |
REVIT_EXE_ROOT20 | Specifies the folder location for the Revit 2020 .EXE file. The default is C:\Program Files\Autodesk\Revit 2020 | ||
REVIT_EXE_ROOT21 | Specifies the folder location for the Revit 2021 .EXE file. The default is C:\Program Files\Autodesk\Revit 2021 | ||
REVIT_EXE_ROOT22 | Specifies the folder location for the Revit 2022 .EXE file. The default is C:\Program Files\Autodesk\Revit 2022 | ||
REVIT_EXE_ROOT23 | Specifies the folder location for the Revit 2023 .EXE file. The default is C:\Program Files\Autodesk\Revit 2023 | ADDINS18 | Specifies the addins folder for Revit 2018. The default is C:\ProgramData\Autodesk\Revit\Addins\2018|
ADDINS19 | Specifies the addins folder for Revit 2019. The default is C:\ProgramData\Autodesk\Revit\Addins\2019 | ||
ADDINS20 | Specifies the addins folder for Revit 2020. The default is C:\ProgramData\Autodesk\Revit\Addins\2020 | ||
ADDINS21 | Specifies the addins folder for Revit 2021. The default is C:\ProgramData\Autodesk\Revit\Addins\2021 | ||
ADDINS22 | Specifies the addins folder for Revit 2022. The default is C:\ProgramData\Autodesk\Revit\Addins\2022 | ||
ADDINS23 | Specifies the addins folder for Revit 2023. The default is C:\ProgramData\Autodesk\Revit\Addins\2023 | ||
INSTALL_SWARM | Specifies whether or not to install V-Ray Swarm: 0 - Does not install Swarm. 1 - Installs Swarm. | ||
SWARM_ENABLED | Specifies whether or not to enable V-Ray Swarm during installation: 0 - Does not enable Swarm. 1 - Enables Swarm. | ||
SWARM_GOAL | Allows you to set in advance the desired percentage of utilization of available resources. Computers added to or removed from V-Ray Swarm are taken into account automatically. The default is 60. | ||
SWARM_DONOTUSELOCALMACHINE | Specifies whether to exclude the local machine from rendering: 0 - The local machine is used. 1 - The local machine is not used. However, V-Ray Swarm proceeds using a small percentage of the local machine's resources to communicate with the nodes. | ||
AUTO_DISCOVERY | Specifies whether the installation should search for other nodes in the network: 0 - Does not search for other nodes in the network. 1 - Enables auto discovery and the installation searches for other nodes in the network. | ||
DISCOVERY_MASTER | Specifies the Coordinator's IP address. | ||
SWARM_TAGS | Tags this node with a descriptor that defies something about the machine, which can later be used to selectively control from inside of Revit. Tags must be separated with a comma. | ||
INSTALL_LICENSE_SERVER
| Specifies whether or not to install the V-Ray license server: 0 - Does not install the V-Ray license server. 1 - Install the V-Ray license server. | ||
OPEN_CHANGELOG
| Specifies whether or not to open the Change Log once the installation is complete: 0 - Does not open the Change Log. 1 - Opens the Change Log. | ||
REMOTE_LICENSE | Specifies whether the V-Ray license server runs locally or on another machine: 0 - The license server runs locally on the same machine. 1 - The server is on a different machine in the network. | ||
LIC_TYPE | Specifies the type of license. | ||
FIREWALL_EXCEPTION | Specifies whether to add a Firewall Exception for the V-Ray license server: 0 - Does not add a Firewall Exception for the V-Ray license server. 1 - Adds a Firewall Exception for the V-Ray license server. | ||
TELEMETRY | Specifies whether anonymous usage statistics is enabled or disabled. |
Fancy Bullets | ||
