changes.mady.by.user Gergana Lilkova
Saved on Nov 27, 2020
Saved on Mar 01, 2021
The Render Channels Container allows you to extract one or more render elements from the final image.
Lighting – The diffuse direct surface lighting.
Specular – The surface specular highlights.
Self Illumination – The self-illumination of the surface.
GI – The diffuse surface global illumination.
Refraction – The refractions on the surface.
Background – The image background as set in the sceneproject, with the rest of the image rendered as black.
Reflection – The reflections on the surface.
Diffuse – The pure diffuse surface color.
Shadows – The diffuse light that was blocked by other objects.
Atmosphere – Atmospheric effects.
Sample Rate – Shows an image where the pixel brightness is directly proportional to the number of samples taken at this pixel.
Bump Normal – The normals generated by bump maps.
DR Bucket – Allows you to extract an image which shows which bucket was rendered by which machine during distributed rendering.
Normals – The surface normals.
Material ID – Provides a mask for individual objects and materials that are easy to select in compositing software.
Material ID (no AA) – Provides a mask for individual objects and materials that are easy to select in compositing software.
Render ID – Creates selection masks based on the node handle of each object.
MultiMatte Materials – Creates red, green and blue selection masks based on the ID Number set within the V-Ray material.
