Height – Specifies the height of the Ground Plane.
Material – Specifies a material for the Ground Plane. Note that selecting a V-Ray material from the drop-down list enables the Infinite Ground Plane. Respectively, removing the selected material disables the Infinite Ground Plane.
UI Text Box
type
note
Note that the global material overrides do not affect the Infinite Ground Plane. If that is needed, the material should be changed manually.
UI Text Box
type
tip
The Infinite Ground Plane scales the material assigned to it by a factor of 100. The material scale can be adjusted from within the V-Ray Asset Editor. In all cases where that material is assigned to other geometries, it is recommended to use a duplicate copy of it.
