Utility Textures allow users to perform a variety of helpful functions on texture maps inside a project (such as compositing textures together and value conversions), as well as provide color corrections option.
A Utility A Utility Texture can be replaced with another Utility Texture or any other type of V-Ray texture via the Replace With New Texture ( ) button, which activates when you select the texture to be replaced. If the texture is an instance, all copies are changed as well.
width10%
width20%
Thumbnail
ThumbnailTitleTextBezier Curve
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VREVIT/Bezier+Curve+Correction
width10%
width20%
Thumbnail
ThumbnailTitleTextColor Correction
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VREVIT/Color+Correction
width10%
width20%
Thumbnail
ThumbnailTitleTextMix Map
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VREVIT/Mix+Map
width10%
width10%
width20%
Thumbnail
ThumbnailTitleTextMix Operator
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VREVIT/Mix+Operator
width10%
width20%
Thumbnail
ThumbnailTitleTextMix Value
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VREVIT/Mix+Value
width10%
width20%
Thumbnail
ThumbnailTitleTextMultiSub
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VREVIT/MultiSub
width10%
width10%
width20%
Thumbnail
ThumbnailTitleTextSimple Mix
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VREVIT/Simple+Mix
width10%
width20%
Thumbnail
ThumbnailTitleTextSpline Curve Correction
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VREVIT/Spline+Curve+Correction
width10%
width20%
Thumbnail
ThumbnailTitleTextTriPlanar
ThumbnailPageLinkhttps://docs.chaosgroupchaos.com/display/VREVIT/TriPlanar
width10%
