UI Text Box | |||||
Most numeric V-Ray parameters come with a slider to make fine-tuning easier. Each slider is set to a default range of recommended or commonly used values. If a value above that range is used the slider adapts by increasing its range accordingly (2x the input value) to maintain usability. If a value below the current slider range is used, the slider again adjusts its range by shrinking it to twice the amount of the input value. Note that the slider range does not indicate the parameter's total minimum and maximum input values. The absolute minimum and maximum values of each parameter can be found by hovering over its spinbox.
UI Text Box | ||
The unit-dependent parameters coming from Fur that are always measured in Revit standard units - feet include: Length, Thickness, Curl: Curl radius, Level of Distance: Start Distance, Rate and Distribution: per Area Count(Area) parameter which is measured in square feet. |
Section | |||||||||||||||
UI Text Box | ||
The unit-dependent parameters coming from V-Ray Fur are always measured in Revit standard units - feet. These include: Length, Thickness, Curl: Curl radius, Level of Distance: Start Distance, Rate and Distribution: per Area Count(Area) parameter which is measured in square feet. |
Anchor | ||||
Section | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
