This page provides information about V-Ray Fur in V-Ray for Revit.
width50%
V-Ray Fur is commonly used for simulating grass cover or textile fibers.
width5%
width45%
UI Path
width5%
width45%
Creating Fur:
||V-Ray Asset Editor|| > Create Asset Geometries > Fur
||V-Ray Asset Editor|| > Geometry > Fur
width45%
Assigning Displacement:
||Appearance Manager|| > Materials tab > Add V-Ray Grass/Fur
width5%
Workflow
V-Ray Fur is created from Asset Editor > Geometry > Fur and is assigned from the drop-down menu of each material in the Appearance Manager.
After V-Ray Fur assignment, a V-Ray Fur icon appears next to the selected material in the Appearance Manager. The icon represents the applied V-Ray Fur properties. Left-click on it opens the assigned fur item in the Asset Editor.
Materials with assigned fur can be filtered from the Filter icon (Image Modified), which is located in the search window.
width40%
UI Text Box
typenote
In order to render realistic grass in V-Ray Vision, create Fur in the Asset Editor and rename it to Grass. Only materials associated with that type of Fur (i.e. using Grass as a key word) will be rendered as covered with realistic 3D grass.
width5%15%
width70%
Image Added
Image Removed
width55%
15%
UI Text Box
typeinfo
Most numeric V-Ray parameters come with a slider to make fine-tuning easier. Each slider is set to a default range of recommended or commonly used values.
If a value above that range is used the slider adapts by increasing its range accordingly (2x the input value) to maintain usability. If a value below the current slider range is used, the slider again adjusts its range by shrinking it to twice the amount of the input value.
Note that the slider range does not indicate the parameter's total minimum and maximum input values. The absolute minimum and maximum values of each parameter can be found by hovering over its spinbox.
Expand
titleClick here to expand a preview of the slider
Image RemovedImage Added
width60%
Distribution – Specifies how the density of strands is determined over the source object:
Per Face – Every face generates the specified number of fur strands. Specifies the number of fur strands per face of the source object.
Per Area – The number of strands for a given face is based on the size of that face. Smaller faces have fewer strands, larger faces have more strands. Every face has at least one strand.
Count (Area) – The number of strands for a given face is based on the size of that face. Smaller faces have fewer strands, larger faces have more strands. Every face has at least one strand. For more information, see the example Count Area below.
Density Map – The map is a multiplier for the strand density. Black portions of the map correspond to zero density (effectively no fur is generated in these areas). White represents the normal strand density, as specified by the Distribution parameter.
Length – Specifies the length of the fur strands. See the Length example and the Maps example below for more information.
Thickness – Specifies the thickness of the fur strands. It measures the strand radius. See the Thickness example and the Maps example below for more information.
Taper – Adds a taper to the individual strands of fur. Increasing this value makes each strand thinner at its upper end and wider at its base. See the Taper example below for more information.
Gravity – Controls the force that pulls fur strands down along the Z-direction. See the Gravity example and the Maps example below for more information.
Bend – Controls the elasticity of the fur strands. When set to 0.0, all strands are stiff and straight lines. Greater values cause the strands to bend (e.g. under the influence of the Gravity parameter). See the Bend example and the Maps example below for more information.
Global Scale – Globally controls the scale of the fur in the project. See the Global Scale example below for more information.
Knots – Controls the number of connected straight segments the fur strands are rendered in. See the Knots example below for more information.
width5%
width35%
UI Text Box
typenote
The unit-dependent parameters coming from V-Ray Fur are always measured in Revit standard units - feet.
These include: Length, Thickness, Curl: Curl radius, Level of Distance: Start Distance, Rate and Distribution: per Area Count(Area) parameter which is measured in square feet.
Anchor
counta
counta
width10%
width40%
Example: Count Area
width40%
Example: Length
width10%
width10%
width40%
Image slider
minLabel86.40
startIndex2
maxLabel1382.40
Panel
borderStylenone
Count Area = 86.40
Panel
borderStylenone
Count Area = 172.80
Panel
borderStylenone
Count Area = 345.60
Panel
borderStylenone
Count Area = 691.20
Panel
borderStylenone
Count Area = 1382.40
width40%
Image slider
minLabel0.16
startIndex2
maxLabel0.83
Panel
borderStylenone
Length = 0.16
Panel
borderStylenone
Length = 0.33
Panel
borderStylenone
Length = 0.5
Panel
borderStylenone
Length = 0.66
Panel
borderStylenone
Length = 0.83
width10%
Anchor
thick
thick
width10%
width40%
Example: Thickness
width40%
Example: Taper
width10%
width10%
width40%
Image slider
minLabel0.05
startIndex2
maxLabel0.8
Panel
borderStylenone
Thickness = 0.05
Panel
borderStylenone
Thickness = 0.1
Panel
borderStylenone
Thickness = 0.2
Panel
borderStylenone
Thickness = 0.4
Panel
borderStylenone
Thickness = 0.8
width40%
Image slider
minLabel0.1
startIndex2
maxLabel1
Panel
borderStylenone
Taper = 0.1
Panel
borderStylenone
Taper = 0.3
Panel
borderStylenone
Taper = 0.5
Panel
borderStylenone
Taper = 0.7
Panel
borderStylenone
Taper = 1
width10%
Anchor
grav
grav
width10%
width40%
Example: Gravity
width40%
Example: Bend
width10%
width10%
width40%
Image slider
minLabel-6
startIndex2
maxLabel0
Panel
borderStylenone
Gravity = -6
Panel
borderStylenone
Gravity = -4
Panel
borderStylenone
Gravity = -3
Panel
borderStylenone
Gravity = -2
Panel
borderStylenone
Gravity = 0
width40%
Image slider
minLabel0
startIndex2
maxLabel1
Panel
borderStylenone
Bend = 0
Panel
borderStylenone
Bend = 0.3
Panel
borderStylenone
Bend = 0.5
Panel
borderStylenone
Bend = 0.7
Panel
borderStylenone
Bend = 1
width10%
Anchor
glob
glob
width10%
width40%
Example: Global Scale
width40%
Example: Knots
width10%
width10%
width40%
Image slider
minLabel0.1
startIndex2
maxLabel2
Panel
borderStylenone
Global Scale = 0.1
Panel
borderStylenone
Global Scale = 0.5
Panel
borderStylenone
Global Scale = 1
Panel
borderStylenone
Global Scale = 1.5
Panel
borderStylenone
Global Scale = 2
width40%
Image slider
minLabel3
startIndex2
maxLabel7
Panel
borderStylenone
Knots = 3
Panel
borderStylenone
Knots = 4
Panel
borderStylenone
Knots = 5
Panel
borderStylenone
Knots = 6
Panel
borderStylenone
Knots = 7
width10%
Variance
width60%
The Direction, Length, Thickness and Gravity parameters in this rollout add variation to their corresponding parameters from the Parameters rollout. Values range from 0.0 (no variation) to 1.0. See the Variance examples below for more information.
Bend Direction Map – Specifies a bend direction of the fur strands. This is the direction the fur strands are curved to (the amount of curvature is also controlled by the Bend parameter). The red component of the texture is offset along the U texture direction, the green component is the offset along the V texture direction, and the blue component is the offset along the surface normal.
Initial Direction Map – Specifies the initial direction of the fur strands. The red component is offset along the U texture direction, the green component is the offset along the V texture direction, and the blue component is the offset along the surface normal.
width5%
width35%
Anchor
variance
variance
width10%
width40%
Variance Direction
Before after
afterLabel1
beforeLabel0
Panel
borderStylenone
Panel
borderStylenone
width40%
Variance Gravity
Before after
afterLabel1
beforeLabel0
Panel
borderStylenone
Panel
borderStylenone
width10%
width10%
width40%
Variance Length
Before after
afterLabel1
beforeLabel0
Panel
borderStylenone
Panel
borderStylenone
width40%
Variance Thickness
Before after
afterLabel1
beforeLabel0
Panel
borderStylenone
Panel
borderStylenone
width10%
Curl
width60%
Curl – When enabled, adds curls to the fur.
Curl Radius – Specifies the radius of an individual curl. See the Curl Radius example below for more information.
Curl Radius Variation – Allows you to add variation to the curl radius of the fur strands. See the Curl Radius Variation example below for more information.
Number of curls – Specifies the number of curls on a strand. See the Number of Curls example below for more information.
Curl Map – This map is a multiplier for the strand Curl. Black portions of the map correspond to no curl, and white represents the set curl, as specified by the Distribution parameters.
width5%
width35%
Anchor
curlr
curlr
width10%
width40%
Example: Curl Radius
width40%
Example: Curl Radius Variation
width10%
width10%
width40%
Image slider
minLabel0
startIndex2
maxLabel0.16
Panel
borderStylenone
Curl Radius = 0
Panel
borderStylenone
Curl Radius = 0.04
Panel
borderStylenone
Curl Radius = 0.08
Panel
borderStylenone
Curl Radius = 0.12
Panel
borderStylenone
Curl Radius = 0.16
width40%
Image slider
minLabel0
startIndex2
maxLabel1
Panel
borderStylenone
Curl Radius Variation = 0
Panel
borderStylenone
Curl Radius Variation = 0.25
Panel
borderStylenone
Curl Radius Variation = 0.50
Panel
borderStylenone
Curl Radius Variation = 0.75
Panel
borderStylenone
Curl Radius Variation = 1
width10%
Anchor
curln
curln
width10%
width40%
Example: Number of Curls
width40%
Example: Maps
width10%
width10%
width40%
Image slider
minLabel0
startIndex2
maxLabel4
Panel
borderStylenone
Number of Curls = 0
Panel
borderStylenone
Number of Curls = 1
Panel
borderStylenone
Number of Curls = 2
Panel
borderStylenone
Number of Curls = 3
Panel
borderStylenone
Number of Curls = 4
width40%
Image slider
Panel
borderStylenone
Default Parameter
Panel
borderStylenone
Bend Map
Panel
borderStylenone
Density Map
Panel
borderStylenone
Gravity Map
Panel
borderStylenone
Length Map
Panel
borderStylenone
Thickness Map
Panel
borderStylenone
Curl Map
Panel
borderStylenone
Bend Direction Map
Panel
borderStylenone
width10%
Level of Detail
width60%
Level of detail – When enabled, V-Ray will generate less fur geometry for parts of the project that are far away from the camera. This is done by decreasing the density of the fur strands and increasing their thickness. The level of detail function helps for two things. One, it conserves memory by decreasing the detail where it is too far to be visible, and two, it helps to reduce animation flickering of very fine fur strands when they are far from the camera.
Start distance – Specifies the distance from the camera at which V-Ray will start implementing the Level of detail adjustment. Up to this distance the fur will be generated as specified by the user. After that V-Ray will decrease the density and increase the thickness of the strand by a factor of two for every n units of space specified by the Rate parameter. See the Start distance example for more.
Rate – The rate at which the Level of detail adjustment is applied. Starting from the distance specified in the Start distance parameter, V-Ray decreases the density and increases the thickness of the strands by a factor of two for every n units of space specified by the Rate parameter. See the Rate example for more.
width5%
width35%
Anchor
rateStartDistExample
width10%
width40%
Start Distance
width40%
 Rate
width10%
width10%
width40%
Image slider
Panel
borderStylenone
Start Distance = 50
Panel
borderStylenone
Start Distance = 100
Panel
borderStylenone
Start Distance = 200
Panel
borderStylenone
Start Distance = 400
Panel
borderStylenone
Start Distance = 800
width40%
Image slider
Panel
borderStylenone
Rate = 15
Panel
borderStylenone
Rate = 30
Panel
borderStylenone
Rate = 60
Panel
borderStylenone
Rate = 120
Panel
borderStylenone
Rate = 240
width10%
Material
width60%
Material toggle – When disabled, the V-Ray Fur is rendered in the same material it is associated with in the Appearance Manager. When enabled, it allows you to assign a different material.
Material selector – Specifies a V-Ray material that is applied to the fur geometry.
The input slot () of the Material has a context menu available, if a material is slotted. Note that materials can also be drag-and-dropped into the slot. When you right-click on it, you can Copy, Cut or Clear the selected material. If you left-click on it, the Asset Editor jumps to the slotted material.
UI Text Box
typeinfo
V-Ray Fur produces flat strands if Hair material is applied to it.
width5%
width35%
Options
width60%
Gravity Direction – Manually specifies the gravity vector.
width5%
width35%
Fancy Bullets
typecircle
  • When a Fur geometry is added to the material of a Scatter guest, it is ignored for the scattered instances. The Fur is also ignored for the original instance geometry added as a guest.
